How often do you change anti-freeze on Kubotas?
   / How often do you change anti-freeze on Kubotas? #21
Every 3 years, or more if it's in a dusty environment.
May I ask what bearing "dusty environment" has to do with life of anti-freeze in a sealed by radiator cap cooling system?
Thanks,Jim
   / How often do you change anti-freeze on Kubotas? #22
Thanks,Jim
Depends on the system, if it has a separate expansion tank that is open to atmosphere then in very heavy dust applications I can see it contaminating the system.
A lot of the newer systems have a sealed expansion system and shouldn't have any issues with dust.
   / How often do you change anti-freeze on Kubotas? #23
Do a dc voltage check to check the condition of your antifreeze , (Google it )most of these compact tractor have a parent bore diesel engine a coolant system flush and replace with a coolant like Peak Final charge would be just fine....if you happen to have a wet sleeve engine a more robust antifreeze would be in order
10 ft Shipping Container (A55973)
10 ft Shipping...
2025 Mini Excavator (A56857)
2025 Mini...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
