How often do you change anti-freeze on Kubotas?
   / How often do you change anti-freeze on Kubotas? #21
Every 3 years, or more if it's in a dusty environment.
May I ask what bearing "dusty environment" has to do with life of anti-freeze in a sealed by radiator cap cooling system?
Thanks,Jim
   / How often do you change anti-freeze on Kubotas? #22
Thanks,Jim
Depends on the system, if it has a separate expansion tank that is open to atmosphere then in very heavy dust applications I can see it contaminating the system.
A lot of the newer systems have a sealed expansion system and shouldn't have any issues with dust.
   / How often do you change anti-freeze on Kubotas? #23
Do a dc voltage check to check the condition of your antifreeze , (Google it )most of these compact tractor have a parent bore diesel engine a coolant system flush and replace with a coolant like Peak Final charge would be just fine....if you happen to have a wet sleeve engine a more robust antifreeze would be in order
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
(2) SPRINKLERS & HI-RISE STANDS (A58374)
(2) SPRINKLERS &...
1253 (A58374)
1253 (A58374)
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
