How often and how much do you grease your brush cutter gearbox?
   / How often and how much do you grease your brush cutter gearbox? #1
Santa Craig Cringle
Lawrence County, AL
Current - 2021 Kioti CX2510, Previous - 1959 Ford 881
I have an old beat up used 5' brush cutter. The previous owner appears to have used grease in the gearbox, and maybe mixed with a little oil too. Pretty sure the gearbox leaks oil, though.
If using grease in the gearbox rather than filling with oil, how often do you fill it with grease, and how much grease do you put in? Since you can't use a fill port to gauge it, do you just fill it until no more can go in, or would it be a problem if you put too much in?
   / How often and how much do you grease your brush cutter gearbox? #2
I keep mine filled to the middle of the housing
   / How often and how much do you grease your brush cutter gearbox? #3
I figure a tube of corn-head equals about a short pint of oil.
If you took a big gulp from a pint of blackberry brandy, you'd have a short pint.
   / How often and how much do you grease your brush cutter gearbox? #4
When a seal starts leaking on a gearbox, I tend to go to corn head grease to keep from having to tear into it. The corn head grease has enough flow to it to allow you to gauge the level the same way you would an oil. Tractor Supply carries it as 00 grease.
David from jax
David from jax
Thanks. That's good information!
   / How often and how much do you grease your brush cutter gearbox? #6
I use it too. It is ~$6.50/qt at TSC. Regular corn head grease is 0, I think. Probably better and sticks around longer, but I havnt seen 0 at that price.
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
JCB Loadall 506B Telehandler (A57453)
JCB Loadall 506B...
11ft Hydraulic Angle Blade  Heavy-Duty, Loader/Grader Mount (A59225)
11ft Hydraulic...
40' High Cube Four Multi Doors Container (A55272)
40' High Cube Four...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Giyi 72" 4-N-1 Bucket (A57149)
Giyi 72" 4-N-1...
