How often and how much do you grease your brush cutter gearbox?
   / How often and how much do you grease your brush cutter gearbox? #1
Santa Craig Cringle
Lawrence County, AL
Current - 2021 Kioti CX2510, Previous - 1959 Ford 881
I have an old beat up used 5' brush cutter. The previous owner appears to have used grease in the gearbox, and maybe mixed with a little oil too. Pretty sure the gearbox leaks oil, though.
If using grease in the gearbox rather than filling with oil, how often do you fill it with grease, and how much grease do you put in? Since you can't use a fill port to gauge it, do you just fill it until no more can go in, or would it be a problem if you put too much in?
   / How often and how much do you grease your brush cutter gearbox? #2
I keep mine filled to the middle of the housing
   / How often and how much do you grease your brush cutter gearbox? #3
I figure a tube of corn-head equals about a short pint of oil.
If you took a big gulp from a pint of blackberry brandy, you'd have a short pint.
   / How often and how much do you grease your brush cutter gearbox? #4
When a seal starts leaking on a gearbox, I tend to go to corn head grease to keep from having to tear into it. The corn head grease has enough flow to it to allow you to gauge the level the same way you would an oil. Tractor Supply carries it as 00 grease.
David from jax
David from jax
Thanks. That's good information!
   / How often and how much do you grease your brush cutter gearbox? #6
I use it too. It is ~$6.50/qt at TSC. Regular corn head grease is 0, I think. Probably better and sticks around longer, but I havnt seen 0 at that price.
10' WROUGHT IRON SITE FENCE (A58376)
10' WROUGHT IRON...
UNUSED FUTURE XDM43 43" HYD DISC MULCHER (A58376)
UNUSED FUTURE...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED JCT HYD POST/TREE PULLER (A58376)
UNUSED JCT HYD...
Lot 256- LINCOLN MARINE STYLE WELDER SHIELD ARC SAE-400, DIESEL, HOURS SHOWING: 1,366 (A59213)
Lot 256- LINCOLN...
LOT: (9) Tires & Rims: 275/80 R22.5, 275/70 R22.5 and other sizes (A59076)
LOT: (9) Tires &...
