3-Point Hitch How Much Sway?
/ How Much Sway? #1
bradrich18
Central Alabama
John Deere 1026R
How much sway should I have when using a box blade? Is there such a thing as too loose or too tight?
/ How Much Sway? #2
I leave 3 or 4 inches of sway.
/ How Much Sway? #3
Too tight would be if the sway chains or buckles bind up real tight in high (or low) position. IMO
Too loose would be if the arms contact the rear tires when using the blade.
In between would be whatever your preference is, as it can be annoying bouncing back and forth when in the "up" carrying position. Turns when working the box blade will be a bit easier if there is some slack in the chains.
/ How Much Sway? #4
I can't allow any sway or my bars rub my tires. I keep it adjusted pretty tight. Doesn't seem to be a problem, especially with a Box blade.
/ How Much Sway?
Thanks for the quick replies. I got the box blade two days ago, and it's the first time I've ever used one. I've got to mess around with it a little, but hopefully it won't rain this weekend and I can spend some time learning how to use it. I appreciate any tips, tricks, suggestions, etc... that anyone has. Thanks.
/ How Much Sway? #6
Pay attention to the length of the top link of the 3PH this will greatly effect how aggressive the BB cuts and loads up. Tilt it forward(shorten the top link) and the blade of the box will dig in a bit more. Tilt it back (lengthen the top link) and the blade will not dig in as much and helps you disperse what you have in the box.. You can crown a road by tilting the BB with your side link. :thumbsup:
/ How Much Sway? #7
Keep an eye out for problems when the 3pt is at the highest lift point - whenever you have the sway linkage kinda snug.
Too tight can result in broken sway linkages when you lift the 3pt up.
AKfish
/ How Much Sway? #8
Make sure you have a small amount of play, the box blade should be able to rock back and forth about an inch or two.
My best advice about using a boxblade is to go very slow, stop forward travel as needed to adjust the box up and down. You need to move slow enough to make real time adjustments for example if your front wheels drop down into a low spot you will need to lower the boxblade to counteract the raising behind the rear axle. Practice makes perfect enjoy the new tool.
/ How Much Sway? #9
Wouldn't a longer upper link cause it to dig in more and a shorter one less. :confused2:
/ How Much Sway? #10
If the tractor is going forward, a longer top link will cause the BB to dig less. If the tractor is going backwards using the BB in bulldozer mode, a longer top link will cause the BB will dig down more. The angle of the BB blade from front to back determines how much the blade digs into the dirt.
Obed
/ How Much Sway? #11
My boxblade sways 3 or for inches. The play helps prevent breaking something if you hit a rock or root.
Fine tuning the top link is the most effective way of getting the most work out of the BB. I normally lower the 3PH all the way down when using the BB. Thus, the BB floats on the ground behind the tractor so running the front wheels into a hole or on a hump does not change the angle of the BB. I don't need to adjust the toplink because of humps or dips unter the front wheels. Floating the BB on the ground takes care of those humps and dips.
Obed
/ How Much Sway? #12
Obed
The OP has a small 1026R, 2 inches amounts to alot of play on this tractor.
/ How Much Sway?
I tightened the turnbuckles up to take some of the slack out of the sway. They're pretty tight, but I still have some sway. Although it's not as bad as it was when I first hooked it up. Most of what I'm going to be using the box blade for is on a hillside in one form or another - whether it be in my yard or on an access road. My main concern is that I break one of the arms while backing up a bumpy hill (I don't have any weights on the front end yet, so I have to back up them). I don't know how hard they are to break, and I don't want to push it too hard.
/ How Much Sway? #14
The lower lift arms are pretty hard to break (even on a 1026R). Much easier to bend/break the sway linkage or the vertical shaft between the rockshaft arms and the lower lift arms.
That happens most often when backing up into a berm of dirt or snow, for example.
AKfish
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
