How much electrical damage did I do
/ How much electrical damage did I do #1
equidawn
Workmaster 50
Mental error on my part, now I have a burned out alternator. 2015 work master50, hooked up wrong cable at battery. Realized I made a mistake, immediately disconnected ground, turned the battery the correct direction.
When I reconnected the battery, alternator started smoking about a minute later. Disconnected it, smoking quit. Wiring seems undamaged, so that’s good. disconnected the power wire from the alternator, and have no dash lights when I turn on the key. Will try clamping the alternator wires to bypass the alternator later, maybe that will get the ignition switch working.
I will be replacing the alternator.
So the question becomes what else have I done? What else do I check?
/ How much electrical damage did I do #2
I'm guessing that you burned out the main fuse that protects the wiring when a person inadvertently hooks the wires up reversed. You should have dash lights even with the alternator disconnected. But remember I'm only guessing as I have no experiences with your model of tractor. Hopefully someone who is familiar with Workmasters can comment.
/ How much electrical damage did I do #3
He should, but this statement,
leads me to think that perhaps there's some sort of wiring setup with which I'm not familiar. @equidawn, could you elaborate a bit on this? Maybe post a picture or two? What wires are you "clamping"?
