How much does it weigh?
/ How much does it weigh? #1
Don172
Prospect, ME
LS G3033
I am new to tractors and am considering buying an LS G3033. I would like to know about how much does this tractor weigh with a front end loader and a backhoe attached. My reason is I am looking to buy a trailer soon. Will this tractor be ok on an 18 foot car hauler trailer with 7000 lb GVWR? Also are people happy with this tractor?
/ How much does it weigh? #3
also if you fill your rear wheels that will add to the weight
Jeff
Ya I can see the weight listed for the tractor is about 2600 Lbs, but I don't know how much the weighted tires, front end loader or backhoe weigh. Does anyone have an estimate based on other equipment this size or know where I can find the information? Thanks for the reply's.
/ How much does it weigh? #6
I looked through my brochures they list the weight of the front end loader LL3102 at 1124lb (no bucket) add 400lb for bucket. No b/h listed, but A 3pt ansung style backhoe was 1200lb add 300lb for sub frame. I guess your tires hold 32gal water 256lb per tire. So 2600+1524+1500+512=6136lb
OK thankyou. I appreciate that. Looks like I may want a little heavier duty trailer because the one i was considering at 7000 lb gvw would only have a payload capacity of about 5500 lbs. Have you been happy with your LS tractor?
/ How much does it weigh? #8
Backhoe and loader weights are on the site. They are in the downloadable brochures.....
/ How much does it weigh? #11
how much does my willmar wrangler 4500 weigh
/ How much does it weigh? #13
Weighed my 2014 G3033H the other day with the LL3102 front loader, a rear Frontier RB2184 blade(450lbs) and 30 gallons of fluid in each rear tire(500lbs total). It weighed almost right at 5000 LBS.
Grace Quick Attach Tree Puller (A66408)
Grace Quick Attach...
2008 Volvo VNL Sleeper Truck, VIN # 4V4NC9EJ98N489293 (A65563)
2008 Volvo VNL...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Water Pump with Engine (A65640)
Water Pump with...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
