How much does Hydro add?
/ How much does Hydro add? #1
Vermontgolfnut
Vermont
Hi folks:
On a smaller tractor (say 20 hp) how much is the difference between gear shift and hydro transmission? I'm curious because it's not evident in the used tractors.
/ How much does Hydro add? #2
Anthony (Tony? Andy?)
That's a highly subjective question. It depends on the type of tractor, brand, and probably a couple other factors that are slipping my mind at the moment. /w3tcompact/icons/crazy.gif
That said, a hydro transmission is generally more expensive than a gear transmission. The difference for a B7500 is about $1000, but it's a "squishy" $1000. I've seen/heard of people getting a hydro'd tractor for about the same as a gear'd version.
... and maybe you don't see them for sale because the owners like them so much???
Tony is fine :)
I can handle squishy....thanks for your feedback.
By the way, it would be on a B1700.
/ How much does Hydro add? #6
A year ago, I purchased a B7500 (in Central NY) and the hydro added $1,600 (before taxes) to the cost over the gear.
I actually ordered the gear, then called the dealer back and told him to change it to the hyro.
I originally wasn't going to spend that much, but one of the reasons in my case for getting hydro was because I have a front snowblower on mine, and with a geared tractor, the blower/PTO wouldn't run when it wasn't in gear, versus with the hydro, the blower /PTO is constantly going (unless I push in the clutch). When moving heavy snow, need to have the capability of stopping and letting the blower catch up sometimes.
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
(2) Liquor Barrels (A64127)
(2) Liquor Barrels...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
