How much damage am I likely to have done to my new tractor?
   / How much damage am I likely to have done to my new tractor? #31
Diesels seem to be rather more forgiving in this area.
It is not something you would want to have happen mid-spark with a gas engine.
Also hard on the turbo for those diesels that are so equipped.
   / How much damage am I likely to have done to my new tractor? #32
I borrowed a flail mower a couple of years ago that was a bit too big for my BX2350 and forgetting its size I engaged the drive without thinking. It stopped the motor dead, instantly, but no apparent damage. Later in the year I noticed the motor fan rubbing on one of the engine mounting brackets, which had torn away from the parent metal bracket and I've always wondered if this was the result of the borrowed flail mower stalling the motor. I suggest you have a close look at all four engine mounts to be sure.
   / How much damage am I likely to have done to my new tractor? #33
Determined to make it last a lifetime, I've been religiously cleaning, greasing, servicing and maintaining my new Kubota B2301 since I bought it earlier this year.
I've been warned that you never want to "stop-dead" the PTO during operation, hence why rotary-tillers and such have shear pins/slip-clutches.
Yet somehow I've managed to "stop-dead" my new tractor 3 times by hitting immoveable objects with my mid mount mower. It appears the MMM does not have a shear pin or anything. One time was on a low tree stump which I stupidly thought was low enough for the mower to go over (no it was NOT). The other two times were on large branches which had come down in the long grass, which I failed to see. In each case BANG the blades stopped-dead and instantaneously stalled the tractor :cry:
The tractor still appears to be working, however I can't stop cringing as I wonder how much damage I might have already inflicted on my new baby.
Can anyone tell this lay-man just what kind of damage / premature wear I may have caused?
I think it is fine. I dead stopped my JD 950 when I caught a root with a box blade ripper. Started smoking & knocking when I resarted it. Bent or broke a piston rod! So I think you will know if you did any real damage right away. My tractor never ran again bought a new one & not a JD.
   / How much damage am I likely to have done to my new tractor? #34
I've had a 2004 New Holland TC35 since it was brand new. It now has over 3500 hours on it. I've lost track of the times I've hit an "immovable object" accidentally in the process of getting work done. Mowers, FEL's, grading blades, all kinds of attachments. The few times any damaged occurred, it was always to the implement itself or something attached to the implement (blade, bucket, etc.). While I would hesitate to say that the tractor itself is indestructible, I would be comfortable saying that what you describe having happened certainly did not damage the tractor. That's also why I would also say it's well worth the money to get a high quality tractor; the steel, the welding, the engineering, that's why so many tractors live to a ripe old age. They really are TOUGH.
  • Good Post
Reactions: JWR
   / How much damage am I likely to have done to my new tractor? #35
I didn't read all the replies, but if not mentioned before, something should 'give' before the shock stops your engine. You either need to adjust the slip clutch if it is in your driveline or go with a lighter shear pin. The idea is the damage should be non existent or at most the cost of a new shear pin.
   / How much damage am I likely to have done to my new tractor? #36
Mid mount mowers do not have those normally.
   / How much damage am I likely to have done to my new tractor? #37
I stalled out my Kubota B3300 when it was new and I was opening up a half acre in 2014. I initially used a middle buster plow, removed boulders the size of 55 gallon drums, then added manure and attempted to till it in. I must have stalled the tractor out at least 9 times when large rocks locked up the Landpride reverse tine tiller. Never damaged the tractor or PTO shaft, but bent up some tiller tines. Over about two months I dump trailered out lots of rocks, but now the soil is excellent and has produced lots of spuds and corn. Kubota tractors are tough little machines and will take a beating.
   / How much damage am I likely to have done to my new tractor? #38
Mowers have belts. It may sound like things are coming to a dead stop, but it's hard to imagine a belt not slipping a small bit before the driveline snaps or the engine is damaged.
   / How much damage am I likely to have done to my new tractor? #39
I worked at Kubota. Saw one come in from hitting a cut off clothes line pipe in the ground. Busted the whole rear end in two. From center line of rear axle from seat to bottom of tractor. We had to get a bare housing and swap all his internals over. I would have bought a back half at a salvage yard. But the dealerships love those in depth mechanic jobs.
   / How much damage am I likely to have done to my new tractor? #40
Aside from the strain on the mower, can someone please explain to me what having a tractor stop-dead like this can do to the tractor/engine? What tractor parts are being stressed exactly? What kind of repairs might I be up for if they keep doing this? (hypothetically...I WON'T keep doing this!!)
Also, why doesn't this brand new Kubota mid-mounted mower attachment have a slip-clutch or shear pin??
Forget the engine damage. No one around here ever heard of damaging an engine due to whatever happens with a MMM. If it was severely sudden enough (say like htting a 6" square steel reinforced concrete post sticking out of the ground several inches while going flat out full rpm...and you hit it with the middle blade ) MAYBE you will do damage to the mid-PTO. Maybe. More likely the blade will bend/give/slip on the gear shaft while being mangled.
And for those saying it would be different if gasoline instead of diesel ... I say nonsense. No reason to believe that either.
The belt is going to act like a slip clutch except for the middle blade.
And as others have said, the reason there is no slip clutch or shear pin is there is no need for them... based on hundreds of thousands of hours experience nationwide over decades of time with many models and many brands.
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2013 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A52707)
2013 CATERPILLAR...
GLEDHILL SPREADER (A52707)
GLEDHILL SPREADER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
