How much damage am I likely to have done to my new tractor?
   / How much damage am I likely to have done to my new tractor? #1
tallguy104
Australia
B2301
Determined to make it last a lifetime, I've been religiously cleaning, greasing, servicing and maintaining my new Kubota B2301 since I bought it earlier this year.
I've been warned that you never want to "stop-dead" the PTO during operation, hence why rotary-tillers and such have shear pins/slip-clutches.
Yet somehow I've managed to "stop-dead" my new tractor 3 times by hitting immoveable objects with my mid mount mower. It appears the MMM does not have a shear pin or anything. One time was on a low tree stump which I stupidly thought was low enough for the mower to go over (no it was NOT). The other two times were on large branches which had come down in the long grass, which I failed to see. In each case BANG the blades stopped-dead and instantaneously stalled the tractor :cry:
The tractor still appears to be working, however I can't stop cringing as I wonder how much damage I might have already inflicted on my new baby.
Can anyone tell this lay-man just what kind of damage / premature wear I may have caused?
   / How much damage am I likely to have done to my new tractor? #2
Probably much more damage to the mower than your tractor. I've stopped my 90 HP JD twice since I got it. Hasn't affected it.
   / How much damage am I likely to have done to my new tractor? #3
Bending the blades is the most likely problem. Aside from that it’s likely nothing happened.
   / How much damage am I likely to have done to my new tractor? #4
Diesels seem to be rather more forgiving in this area.
It is not something you would want to have happen mid-spark with a gas engine.
   / How much damage am I likely to have done to my new tractor? #6
You could have bent the blades but you could also bend a spindle and have the blade hitting something underneath or cut at an angle.
   / How much damage am I likely to have done to my new tractor? #7
From my experience, you have not done any damage to the Kubota engine, but your mower blades probably received some damage. Basically I would look for any blades that are out of alignment, and these now create noticeable vibrations. Blade replacement is recommended.
I also highly recommend you walk your mowing areas looking for debris and stumps. The higher the grass, the more you should walk it. Normally I keep my field grass low, but after long vacations, I walk the field and look for any new debris. I found a new Rabbit mound this way, and flagged it for avoiding. Nothing worse than hitting baby rabbits.
   / How much damage am I likely to have done to my new tractor? #8
Dang... you've unknowingly given your mower the 'stake test'. It's a safety standards test we do when developing mowers to make sure nothing flies out or skitters across the ground when a mower contacts something hard... injuring someone.
In this country (ANSI B71.1 test) a 1" steel rod is fired up from the test cell floor into a running mower snuffing it instantly. The tractor/mower is surrounded by target paper. Parts can't fly off and contact the cardboard in the target area or drop parts onto the floor to pass. Each spindle is tested. The steel stake will have a big 'bite' cut into it and can be bent back 30 deg or so. Each blade will have a large 'round' smashed into the cutting edge too.
Unfortunately, a typical casualty is also a bent spindle pocket. I would lift the discharge chute (or better yet drive your tractor up onto car ramps) and inspect the blade plane alignments at the blade tips. It's easiest if you can de-tension the secondary drive belt allowing the blades to spin independently allowing you to easily get the blades 'tip-to-tip'. You can usually force one blade around to get them together if you can't de-tension. Assuming you have a 3 spindle belly mower, you'll be checking 2 places: LH blade to Center and Center to RH blade. Once you get 2 blade tips together, you're looking for the blade planes to be no more than 1/8" difference in height. You have to spin each blade around 180 deg to check (4 inspections before moving to the next blade pair).
If you find a blade pair that doesn't align in height and the opposite tip is out of alignment by the same amount... you probably have a bent spindle pocket. I would install new blades and check the alignment again. A bent spindle pocket is a bigger deal but dealers usually have a means to straighten one back into position. This is not a home shop fix. If your land is rough enough that you're hitting objects.... maybe you should think about trading the mower for a rotary cutter?
Ok thanks folks. I'll pull the mower deck off and have a good look as suggested. I'll definitely be walking my fields before mowing in future. It's actually only been 2 weeks since I last mowed, but its been so hot and humid here the grass is already 18 inches high!
Aside from the strain on the mower, can someone please explain to me what having a tractor stop-dead like this can do to the tractor/engine? What tractor parts are being stressed exactly? What kind of repairs might I be up for if they keep doing this? (hypothetically...I WON'T keep doing this!!)
Also, why doesn't this brand new Kubota mid-mounted mower attachment have a slip-clutch or shear pin??
   / How much damage am I likely to have done to my new tractor? #10
I can't ever remember seeing a slip clutch on a mid-mount mower or any zero-turn for that matter. Probably because your not expected to be hitting debris on a continuous basis. You need to move up to a rotary cutter to find slip clutches and shear pins on your mower.
I have been mowing with Gravely Proturn 460, a Kubota GR-2120 and a Kioti CK4010 with medium duty rotary cutter for several years now. Any high grass with trees, always requires a short walk around prior to mowing. Especially if you have large old trees. Always Flag or remove debris. You can even drive your mower around looking for debris....without the PTO engaged. Its like a quick recon of the area before mowing.
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
Sundowner Rancher Express 20FT Livestock Trailer (A55315)
Sundowner Rancher...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2005 John Deere 310G 4x4 Extendahoe Loader Backhoe (A55851)
2005 John Deere...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
BUSH HOG 74" ROTARY TILLER (A57192)
BUSH HOG 74"...
