how many units of diesel/hour for CUT's
   / how many units of diesel/hour for CUT's #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Well I tried a search and found tons of threads but only one mentioned fuel use numbers (10 gallons/hour on a JD 8XXX I think). Most devolved into "my brand did better than yours" with no actual numbers.
How much do these CUT's in the 25 to 40 hp range burn in an hour?
I can deal w/ liters or gallons.
My diesels burn about:
7.3L Ford - 4+ gal/hour (about 16MPG going 70mph)
2L VW - about 2-gal/hr (about 40mpg going 70+). Should get better after I break it in and stop driving it like a BOH :)
tia
   / how many units of diesel/hour for CUT's #2
I have a Mahindra 2615HST (26HP) tractor. So far in my uses it burns about 1 gallon or a little less per hour while operating attachments such as a brush hog, snowblower, or loader work. Probably a little less just driving.
   / how many units of diesel/hour for CUT's #3
I think the average is about 1 gallon per hour or so...but it's really hard to know because rarely do we (CUT owners) run for hours on end with the same load like plowing a field.
   / how many units of diesel/hour for CUT's #5
My Kubota B21 (21HP) burns about 1/2 a gallon per hour.
   / how many units of diesel/hour for CUT's #6
My BX2350 is using just a hair over 1/2 gallon per hour.
Thanks for all the responses!!
Keep 'em coming!
   / how many units of diesel/hour for CUT's #9
Round harrow five acres of seedlings, right around half tank , 2.5-3gal, with the JD790. Do ten acres of seedlings and still had just below quater of a tank left. 5 foot round harrow pulls easy.
   / how many units of diesel/hour for CUT's #10
You got me thinking about what my BX24 (23 HP) is getting, so I just had to go out and calculate it. Since I'm in the processes of doing my 300Hr/2Yr service anyway, I figured it's a good time get some hard numbers, but I already knew I was reloading with 5 gals every 15 hrs or so.
Total Gallons Used: 95
Last Refill Hrs: 289.6
Hrs per Gal: (289.6/95) = 3.05
Years ago, I started logging fuel refills on my road vehicles (date, miles, gals, grade), so when I got my BX24 (new) I started a refill log book as well, with greasing and service notes. When I buy diesel, I always make sure I put as close to 5 gals as possible into my fuel cans so I can be reasonably accurate.
No mowing, mostly FEL work, some rototilling & box blading, a little backhoe and tree limb chipping work.
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
