how many units of diesel/hour for CUT's
   / how many units of diesel/hour for CUT's #31
Why don't we all just get on Fuelly.com and track this?
It's not set up for tractors, but if there are enough of "us" on there, maybe they'll add a category.
Click on that thing below.
   / how many units of diesel/hour for CUT's #32
The design criteria used by at least some diesel engine manufacturers calls for a target for fuel consumption of 0.5 lb/hp hour. Bear in mind that a 100 hp engine is not putting out 100 hp at all engine speeds and loads except at, for example, rated speed and loaded to the peak of the hp curve. That said, each of us is going to see a variety of rates of fuel consumption based on the varied loads imposed on our tractors.
   / how many units of diesel/hour for CUT's #33
tossing in my .02 cents worth
my new ccyanmar 2400 24 hp
have 38 hours on it now the first 15 mostly screwing around the other a split between the Boxblade ( got it thrown in on the deal by the dealer never thought Id use it what a fantastic tool) and tiller getting about 1/2 gallon per hour running it usually a little less than 3000 rpm gets twice the hour per gallon then my 16 hp cub ever did
and does 3 times the work
   / how many units of diesel/hour for CUT's #34
ford 5000 or NH 7610s.. ( 70hp / 95 hp ).. both are using about 1.67 gph while pulling mowers 10'/15'
soundguy
   / how many units of diesel/hour for CUT's #35
My 2003 Kioti DK 45, best i ever got was 1 gallon an hour usually 1.3 to 1.5 gallons an hour.
   / how many units of diesel/hour for CUT's #36
My 2008 Kubota B2620 with 26HP used 1.5 gallons in 3 hours @ 1800 rpm last night. I was doing box blading and FEL work for exactly 3 hours straight. That works out to 1/2 gallon per hour at that 1800 rpms. I can live with that!
:p
Troy
I fully agree -
Half a gallon per hour, or about $1.25 is well worth the 4 wheelin', dirt moving, hauling fun.
   / how many units of diesel/hour for CUT's #38
I figure I can spend $20 taking the wife to a movie (as long as she says she isnt hungry and just eats my popcorn) or
spend the afternoon playin in the dirt
   / how many units of diesel/hour for CUT's #39
But are you going to sleep in your bed or in the garage with the tractor?:p
   / how many units of diesel/hour for CUT's #40
Kinda hard to measure exactly ain't it? But I think,my ck30 kioti uses about 1 gal to one hour of pto work,bought it last fall,bet the newer epa approved motors don't do as well as the older ones,[don't seem like it to me],that would just about be par for course,would think the newer motors came about as to pollution,right?Wondering what kinda test that would be?I mean if it burns more fuel than old ones,how could that be less polluting??
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
Eagle Weathervane (A55853)
Eagle Weathervane...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
