How Many Have More Than One Tractor?
   / How Many Have More Than One Tractor? #181
2 deutz (100hp and 76hp) and a kioti (35hp),
the big one,
   / How Many Have More Than One Tractor? #184
From what I see, the majority of tractor owners here and everywhere else have only one tractor.
I mean more than one that runs, you maintain, and use regularly... (Don't count the old broke down one behind the barn with 2 flats. :LOL: )
Surprisingly, after replacing my 2 previous tractors with newer, more improved ones, I find I have have about the same hours on both new ones.
I'd hate to have to choose between them, if I had to pick only one. I really have a use for both.
How many of you are multiple machine owners? Could you get by with just one? Which one would you pick if you had to?
I have a L6060 HST Kubota and a 40 yr old 40HP diesel 4WD Cub Cadet SS 7360, I use both and both run like new. Grapple on the Kubota and bucket, bush hog on the other.
   / How Many Have More Than One Tractor? #185
I have a JD x595 (23 HP diesel 4x4) and a Ford 555D (~72 HP diesel 4x4/backhoe). They both have their individual uses and I would rather not be without either of them.
   / How Many Have More Than One Tractor? #186
An X with a 45 loader, now that's a useful little machine.
   / How Many Have More Than One Tractor? #189
That's really impressive!
The factory relief pressure on these machines is only set to 900-1000 psi, which is why they're anemic as they come. Doesn't take much to wake them up a little. The K92 hydro in these is rated for 1500. That's a 25 HP gasser with a 54" deck hanging in the air. Just gotta be sure to have enough ballast, as the machine itself isn't very heavy. I mostly use the 555D (12,000 pound breakout, 6,000 to full height) for heavy lifting now, but the small machine is definitely handy for getting into spaces that it can't.
Kubota L4701 (A53317)
Kubota U55-4 (A57148)
2022 Ram 2500 (A55973)
Miscellaneous Tech and Electronics (A56860)
Miscellaneous Tech...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
Metal Grizzly Bear Statue (A57454)
Metal Grizzly Bear...
