How Many Have More Than One Tractor?
/ How Many Have More Than One Tractor? #161
1 tractor with several implements, 2 ride-on mowers, 1 ATV with snowblade, 1 zero-turn mower
/ How Many Have More Than One Tractor? #162
1 tractor (Kioti DK 35) Does everything I need, Don't need any more
1 Wheel Horse garden tractor
2 zero turn mowers (Hustler Super z and Snapper Pro s200xt)
/ How Many Have More Than One Tractor? #164
Yes. Jcb 1550b, Massey Ferguson MF400 loader/ripper with 4 in 1, Ford 445a loader with gannon scraper and quick change, have grapple and auger, Gradall lift, Clark lift and JLG 40, manlift.
/ How Many Have More Than One Tractor? #165
2 Kubota 4 WDs
1 Massey 2 WD
1 Iseki 4 WD garden tractor
1 Troybilt Horse 2 Wheel (if that counts)
1 BCS 2 Wheel (if that counts)
+ Partial owner of another Masey 2 WD
And I am looking to add 1
/ How Many Have More Than One Tractor? #166
Kioti CK3510 SE Hst open station for sunny days
Kioti NX6010 Cab Hst for cold weather months, or if more power is required
/ How Many Have More Than One Tractor? #167
From what I see, the majority of tractor owners here and everywhere else have only one tractor.
I mean more than one that runs, you maintain, and use regularly... (Don't count the old broke down one behind the barn with 2 flats. :LOL: )
Surprisingly, after replacing my 2 previous tractors with newer, more improved ones, I find I have have about the same hours on both new ones.
I'd hate to have to choose between them, if I had to pick only one. I really have a use for both.
How many of you are multiple machine owners? Could you get by with just one? Which one would you pick if you had to?
I have 2, & both serve there purpose, & both compliment each other as far as what one will do were the other is limited; The other one will fill the void; So I'd have to say they are a team, & I would not pick one over the other; They are both keepers. IMG_20201003_134009.jpg
/ How Many Have More Than One Tractor? #168
I have two: a JD 855 hydro 24 hp, a JD 870 with backhoe and bigger bucket. The JD 870, 3-range, 3 speed trans, big turf tires, it's the most useful, most used. The compact 855 is useful for brush cutting, a power wheel barrel, moving things around the property.
/ How Many Have More Than One Tractor? #169
I have 6, 25-65 HP and use all of them for one thing or another. At 82 and working alone, hooking up implements is a chore most of the time so I have dedicated tractors for certain jobs. The little LS with loader was bought to be handy around the place. It has proven itself repeatedly. If I ever totally quit farming, I will keep it.
/ How Many Have More Than One Tractor? #170
How I feel about my little Kubota BX23
/ How Many Have More Than One Tractor? #171
We have 2 currently: Allis Chalmers D17 and a Kubota B26 TLB. Also a ZD 1211 mower.
/ How Many Have More Than One Tractor? #173
I have 4 if you count the JD2210 SCUT as a tractor.
/ How Many Have More Than One Tractor? #175
I have 2, MX5400 and B2601, KX033-4 excavator, SSV65 Skid Steer. Excavator and skid steer are new. 72in brush cutter on skid steer. 2 RTV.Several other attachments for both tractors. Kubota all the way for me, have a great dealer.
/ How Many Have More Than One Tractor? #176
I got 3....
/ How Many Have More Than One Tractor? #178
Used to have 3 at one point. Kubota B7000, Toselli 226 and Toselli 340.
View attachment 832346 View attachment 832347
Then, I needed a bigger/higher HP one and sold everything to get a single tractor.
And now, I kinda could use another tractor to keep at home, so I didn't have to haul a tractor between proprieties so often. 😅
Maybe someday, I'll find a good deal on one that I can restore and keep around. Just need it to till the orchards for the most part.
Turns out the deal did appear and I'm now an owner of 2 tractors.
It's a project, quite a project. More about it on this thread: So I did a thing... Agria 8900D
/ How Many Have More Than One Tractor? #179
M6040 for real tractor work and T1460 for mowing and towing the wood splitter. I guess the JD 450C qualifies as a crawler tractor 😊
2020 CATERPILLAR D1 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
iDrive TDS-2010H...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
Kubota M4700 (A60462)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
