How Many Have More Than One Tractor?
   / How Many Have More Than One Tractor? #151
Based on observation of myself, not necessarily a deliberately and consciously chosen principle, it seems that I have a belief that anything worth owning is worth having more than one of. My wife and I realized at one point that the number of things we have multiples of felt a bit ridiculous. Mostly simple tools, mind you, but it happens more often than not that if someone asks something like, "Do you have a chainsaw?" my answer is, "Well, yeah, I have four of them." Or, "Do you have a backhoe?" "Why, I have two of them, of course."
   / How Many Have More Than One Tractor? #152
How many wives? :ROFLMAO:
   / How Many Have More Than One Tractor? #153
For years, I just had one tractor with a loader, and when it was down, I had to get creative when it was time to feed a round bale. Most common reason for that tractor to be down was a blown hose, but it could be anything, and it usually takes me a week to get the old part off, go to town to buy the new part, and then get it back together.
Now I have three loaders and it's so much nicer when something breaks down. I might have to drag a batwing behind me when getting that round bale, but that's a lot better then hooking up a hay spear to the 3 point hitch and not being able to put the bale in the cradle. They go through the bale twice as fast if it's on the ground without a ring around it.
   / How Many Have More Than One Tractor? #154
Branson 3120 which I bought new in 2011. Has FEL. Bought a CASE IH Farmall 50A new in 2016. No FEL. Use the CASE for brush hogging 11 acres of pasture and several acres of pines; as well as pulling a 'Bush-N-Bog' (aka New Ground) disc set. Use the Branson for most other things including pulling a 5 foot brush hog thru some of the closer planted pines; also for moving large round bales. For what it's worth, I also have a 1952 Farmall Cub 'yard ornament'.
   / How Many Have More Than One Tractor? #155
I know that drill, I spent enough time rolling a 4x5 bale into a pickup with BX2200 and rolling back off at the cattle. Still better than hauling small loads in a yard trailer and an ATV.
   / How Many Have More Than One Tractor? #156
This was me. Then my trusty old John Deere lost an engine - antifreeze drained into the crankcase. I called around to several dealers and was told it would be anywhere from $15,000 to $20,000 for a rebuilt engine - or to have them rebuild mine. This for a tractor I'd paid only $7,000 for. Not going to happen!
So I began my search for another tractor and lucked out, finding a Kubota M7060 with barely any hours on it and the price was right so I bought it.
Wouldn't you know it...a few months later I found out that a guy I used to work with collected old tractors and restored them. I contacted him. For $3000 he rebuilt the whole engine in the John Deere plus did a few other things this 60 year old tractor needed. That was over 5 years ago and I've been using both tractors and wondering how I ever got by with only one!
   / How Many Have More Than One Tractor? #157
I run into that more and more… both the convenience of multiple tractors and also the discrepancy in the cost of repairs… somebody must be spending 15-20k but no body I know…
   / How Many Have More Than One Tractor? #158
We have two .
A couple that tractors 🚜 together , stays together.
   / How Many Have More Than One Tractor? #159
All 8 tractors are functional if you consider functional less than 8 hours of work. If not, 4 are functional.
   / How Many Have More Than One Tractor? #160
Why would anyone have just one? What would you do if it got stuck in a swamp and needed to be pulled out?
Good point. That's when it helps if you have friends.
Recently, I have been a little more daring and got hung up a few times. Fortunately, I was able to use my Jeep Trailhawk to tug it out.
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2011 JACK COUNTY 130 BBL VACUUM  TRAILER (A58214)
2011 JACK COUNTY...
White Metal Roof Panels (A55758)
White Metal Roof...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KMC POULTRY HOUSE KEEPER (A58374)
KMC POULTRY HOUSE...
