How Many Have More Than One Tractor?
/ How Many Have More Than One Tractor? #1
rockinbbar
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
From what I see, the majority of tractor owners here and everywhere else have only one tractor.
I mean more than one that runs, you maintain, and use regularly... (Don't count the old broke down one behind the barn with 2 flats. :LOL: )
Surprisingly, after replacing my 2 previous tractors with newer, more improved ones, I find I have have about the same hours on both new ones.
I'd hate to have to choose between them, if I had to pick only one. I really have a use for both.
How many of you are multiple machine owners? Could you get by with just one? Which one would you pick if you had to?
/ How Many Have More Than One Tractor? #2
I have a BX2200 that I put over 4500 hours on and finally added a bigger LS XG3135H a couple of years ago, now has ~600 hours. I managed with BX for 20+ years but is is sure nice to have the bigger machine. I can't see doing without either. That tough little bugger BX is just too handy for a lot of things.....
/ How Many Have More Than One Tractor? #3
Does an industrial backhoe/loader (JCB) count?
How about my JD 430 (diesel) garden tractor that I use as a mower?
If not, then I only have one. International 1066 with a 15' flexwing to cut a couple fields.
(all three get used but I probably use the backhoe the most)
/ How Many Have More Than One Tractor? #4
Couldn’t possibly get by with one. Had 4, currently have 3, would like a 4th again.
The 4th would just have my CX-15 attached to it and be used only for mowing/snowplowing.
The other 3 for hay farming.
One is always hooked to the big square baler-wouldn’t want it any other way. Another hooked to hay mower. These attachments are not much fun to attach/detatch.
Also have (2) 72” zero turns.
A tracked skid loader/teleskid would be great, too.
Would have to hit it big with $$ to afford the 4th and the tele-skid
/ How Many Have More Than One Tractor? #5
I have a few, I kinda like tractors!
/ How Many Have More Than One Tractor? #6
I have a MX5200 Kubota and a 773 Bobcat Skid Steer. For me it's an ideal combo. Each has its advantages and they can share Bucket and fork attachments. The tractor gets a lot more hours but the SS needed for some mowing and clean up. Does a forklift count?
The 5k capacity CAT is an indispensable tool. These 3 cover whatever needs to be done around the ranch.
/ How Many Have More Than One Tractor? #7
Used to have 3 at one point. Kubota B7000, Toselli 226 and Toselli 340.
Then, I needed a bigger/higher HP one and sold everything to get a single tractor.
And now, I kinda could use another tractor to keep at home, so I didn't have to haul a tractor between proprieties so often. 😅
Maybe someday, I'll find a good deal on one that I can restore and keep around. Just need it to till the orchards for the most part.
/ How Many Have More Than One Tractor? #8
View attachment 832346 View attachment 832347
My buddy keeps a few smaller tractors. Each set up for specific tasks. One has a brush hog mower on it, one has a weed tank/sprayer setup, one is a Ford grading tractor with FEL and box scraper. That one is 50 hp size. But all lack 4wd and so he's on the lookout for another one.
/ How Many Have More Than One Tractor? #9
I have 5 tractors, one skid steer, one mini excavator, and a Ditch Witch RT40 trencher
2 Kubota Grand L6060's one Kubota L5740, one Kubota M4700 that is mostly a spare, and one John Deere 3720
My business is building and maintaining athletic fields, so I use most of them regularly.
/ How Many Have More Than One Tractor? #12
I'm at 4 at the present time just for my driveway and yard work.
An IH 574, Branson 8050, New Holland 8160, Kioti 2620SEC. Then for a lawn mower a Kubota F2000.
I still have to swap implements at times so I need a few more.
Then I also have access to over a dozen more at the farm.
/ How Many Have More Than One Tractor? #13
I have two, Kubota MX5800 HST and L6060 HSTC. I could get by with one but at my age, it gets to be a real chore to constantly swap implements, especially the BH92 hoe.
I minimize implement swapping by leaving the hoe on the MX and mow & plow with the L.
When there is a lot of road work to be done, my neighbor uses the MX while I use the L. That way, the job goes twice as fast with minimum disruption to road traffic.
Are two tractors necessary, no but it sure makes life easier around here. Having three would be even better! ;)
/ How Many Have More Than One Tractor? #14
I have but 1. It is more than sufficient, and I do not mind changing implements. Having Pats quick hitch and hydraulic top and tilt makes changing implements pretty easy.
But changing to or from the backhoe is a bit more involved!
So no desire for another tractor; but an excavator would be great!
/ How Many Have More Than One Tractor? #15
My son and I have two;perfect combo I.M.H.O,an L4240 HSTC and a geared open station L3000DT.
/ How Many Have More Than One Tractor? #17
2 old Kubotas here, my old 4150 doesn't have a loader no desire to cobble one on it either. 5k and 3k occasionally hard hrs respectfully. One mans junk is my treasure if the price is right.
/ How Many Have More Than One Tractor? #18
Have two, old Ford 850 for the heavier work and JD 1025R for the around the house, tight areas plus any heavy lifting (at least as heavy as I do anymore). Went for YEARS with only one tractor and don't want to go back. Each tractor has a purpose and both see regular use.
My SIL and I joke about having a tractor for each implement we own... Ah the dream of changing keys not implements.
/ How Many Have More Than One Tractor? #20
Isn't the goal to have one tractor per implement?
I need a lot more tractors ! :oops:
Maybe we should start a new thread ? How many implements do you own? :LOL:
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
43018CFL (A59228)
43018CFL (A59228)
