How long to let a very over grazed pasture sit?
   / How long to let a very over grazed pasture sit? #101
I think you will want to till it in directly after spreading or the nitrogen will dissipate in the open air. Anyone know if this would happen with 18/18/18? I know it does with Urea, I've had it happen.
   / How long to let a very over grazed pasture sit? #102
Local advice may vary, but here we just time application before a rain forecast, and hope it's not a monsoon that's going to wash everything away. We can get rain rates above 6 inches per hour, but being a lot farther north than Florida, that kind of stuff definitely happens with less frequency up here. So, usually not a huge problem.
Any thoughts on a spring loaded cultivator instead of a disc for field prep? It looks a bit like a cross between a light chisel plow and a cultivator from the picks, but price is right
   / How long to let a very over grazed pasture sit? #104
for your soil (fluffy sand) anything would work but I would look at what will be your future used for it.
Well, the dang price of 5 and 6 ft disc harrows is insane locally... $975 for a rusty used 6 ft disc? I found one about 2h30m away for $75, but "every disc will need replaced" which is fine; but if you need bearings, spacer, ecr; the cost to rebuild would be atleast $600.
Future use.... maybe some deer/turkey food plots, but mostly pasture and future pasture.
I'm also on the hunt for a cheap used fertilizer spreader, for palletized lime, fertilizer and seed; but same story, almost new prices; or destroyed gear box, missing shaft, and no spreader dics...
   / How long to let a very over grazed pasture sit? #106
yes it will happen tilling would reduce that or a light rain.
   / How long to let a very over grazed pasture sit? #107
I would put the rebuild price double that... I used a 3 point PTO rotary spreader for fertilizing and seeding, not as efficient but a lot cheaper... to be honest with the area you have (a few acres) go buy a walk behind or a pull behind a ATV if a walk behind Jimmy rig a hand drill on it and mount it on a quad.
just something to consider.
or these
or these
Yeah, I actually have one already, and have considered that; I have also considered the $199 Vevor towable, 100# capacity, drop spreader, that has the rotating teeth on the front; and the putting a piece of chain or something behind (or fabri cobbling a rear roller).
   / How long to let a very over grazed pasture sit? #109
yes you want to roll it after seeding you want a good soil to seed contact for them to sprout ... if you walk and your boot sink in a inch its too soft.
I did start a new thread in an attempt to ID what I just bought. It is missing 2 springs on the far right side ripper; and it's rusty, and the bolt on tips are loose; but appear reversible
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2001 CASE 570LXT Box Blade (A59213)
2001 CASE 570LXT...
