How long should it last?
/ How long should it last? #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
Being new to Mig I have gone through two 80cuft bottles in about 10lbs of wire. I was told to run the pressure at 20-25psi.
Does this sound right? If so that stuff goes fast, in my opinion. Might be too costly for me to run with gas for most of my jobs. Seems like it was about $65 to fill last.
/ How long should it last? #2
boy, i run mine between 20-25cfh.....and i dont run thru nearly as much gas as your talking about. I have a small 120 volt mig unit, and it has small 75/25 argoc /co2 tanks. the tank lasts a long time. but i have never measured it against the weight of wire i run.
It would take me a long time to burn 10# of 0.30 wire in my machine.
i found this on this other welding site...dont know how accurate it is.
Cyl cu ft size divided by whatever you normally set cfh to on flowmeter. In a perfect world an 80cf cyl with flow set at 20cfh would give about 4 hours weld time. It's not a perfect world, so allow for losses.
If you want to figure out how long tank will last in relation to lbs of wire, you'll have to figure out your wire speed in inches per minute and how many inches of wire = 1 lb. I never attempted to do the math, but it's possible to figure out.
Argon/CO2 tank
boy, i run mine between 20-25psi.....and i dont run thru nearly as much gas as your talking about. I have a small 120 volt mig unit, and it has small 75/25 argoc /co2 tanks. the tank lasts a long time. but i have never measured it against the weight of wire i run.
If you want to figure out how long tank will last in relation to lbs of wire, you'll have to figure out your wire speed in inches per minute and how many inches of wire = 1 lb. I never attempted to do the math, but it's possible to figure out.​
Argon/CO2 tank
Well, there has prob been 4 hrs of welding, overall. I guess. That sure doesn't seem like a long time to me. I am currently finishing up my trailer, guess it will be flux core for the most part.
/ How long should it last? #4
You surely mean 20 - 25 CFH not PSI. You can turn your reg down to about 15 cfh indoors or turn it down until you get porrosity then turn it up a little. If you have an 80 cf tank, It will last for 4 hrs of trigger pull with your reg set at 20cfh. You can't judge by how much wire you burn.
/ How long should it last? #5
I f you have a leak or forget to turn off your tank.. You will be surprised how fast it goes away. Shut that tank off...
/ How long should it last? #6
Get yourself a Miller Mig welding slide rule guide, it will show you what size wire, wire speed and gas flow to use for the stock thickness.
/ How long should it last? #7
yup...fixed. thank you
/ How long should it last? #8
The high pressure bottle valves are also double seated. When you open the bottle valve to turn on the gas, open it all the way till the valve won't turn any more. This engages the upper valve seat, and keeps the high pressure gas from leaking around the handle shaft seal...
After you open the bottle valve, It is also a good idea to spray the valve, reg and flow meter occasionally with a soapy water mix to check for leaks...
As mentioned, 20-25CFh is a guideline. If you are inside with no wind, you only need enough flow to deliver enough gas to displace the atmosphere/O2 and keep it away untill the weld pubble skins over.
Get a piece of scrap and try a pass with no gas on. It will be ugly and sound different. Then start to add gas in small stages and see what happens. If you are in a no wind situation, you can typically run the gas down pretty low and still maintain weld quality...
My .02
/ How long should it last? #9
My .02
From my Miller guide the range is 10 to 17 CUF/HR depending on the stock.
/ How long should it last? #10
You could also consider using straight CO2 with your MIG. A 20 lb CO2 bottle gives you 160 cu ft of gas, and the last time I had one filled it was around $20.
I personally think that the CO2 gives better penetration. The welds are a little rougher than with C25, but they aren't as bad as some would have you think.
Stan
Well, I did check the tank for leaks, and found none. I was appalled at how fast it went. As for pretty welds with the CO2 Argon mix, vs. the straight CO2, I think the flux core welds look pretty decent, if that's any indicator.
Maybe I will check on the CO2 price.
I will also try to lower the pressure too.
/ How long should it last? #14
If your talking ltr/min I run mine at between 15 & 17 ltr/min depending on wind, lasts pretty well, only refill once or twice a year, and I do a lot of weekend welding. Prob go through about 2-3 bottles to 15kg of 0.9mm wire
Flux cored wire sucks, tried that before, ended up going back to a stick welder, easier and cleaner, plus much stronger welds.
/ How long should it last? #16
Have you ever tried using FabShield 21 B not 23 by Hobart?
I find the slag is easy to deal with, it is a brown-orange powered like talk and just brushes off.
http://www.hobartbrothers.com/pdf/datasheets/Fabshield21B.pdf
/ How long should it last? #17
My supplier puts the gauges on tanks and makes sure they are filled like they should be before I purchase. I don't keep track of usage. I use CO2 was $20 on last fill up.
Well I thought it was all psi, just assumed, but will look at the gauges to see. As for the flux core, I seem to actually be able to get good welds more often than with the gas. Of course I am not a real good welder either.
One thing I really have trouble with, using gas/solid wire, is when you're welding inside a corner or tight spot that doesn't allow the gas to shield it very well.
/ How long should it last? #19
Flux core runs a bit hotter than the same size solid wire, because the flux core reduces the cross sectional area.
You really need to try Hobart Fabshield 21B.
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
Massey Ferguson 573 (A60462)
Massey Ferguson...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
