Tractor Sizing How important is rear diff lock on CUT?
   / How important is rear diff lock on CUT? #141
The technology with HST is fine, but how well does it work in extreme cold? And also how is the power loss in the system?
Looked into it when buying new tractor, but the price difference was considerable, - and the determining factor.
My idea of extreme cold is double digit negative temps. NO issues with the HST there. Power loss? I haven't driven a CK35 shuttle so I don't know for sure if there is a loss, but I've never wanted for power, maybe traction, but not power. Price difference here is about 1K, negligible over the cost of a new machine, and well worth it even if it's not.
   / How important is rear diff lock on CUT? #142
Fair enough, but here the price difference would have been closer to 10K equivalent.
   / How important is rear diff lock on CUT? #143
Both machines in the picture are hydrostatic drive as all the rollers behind them so there is no size limit on where a hydrostatic drive can be useful.
   / How important is rear diff lock on CUT? #145
I think the issues would be amply dealt with by a little up front prep using contact heat on the trans case and synthetic oil n the HST. The fact that the HST is less efficient is usually only important where your fuel costs are a deal breaker. Long term high force use like in plowing the soil would be better with gear. Greater fuel use ... and heat from losses could damage an HST that wasnt amply sized for the continuous drive hp required.
   / How important is rear diff lock on CUT? #147
You won't get much argument from me on using a gear drive system for plowing. Not that I don't think hydro's can do it, and be safe and cooled properly for this task, but the question becomes why hydro for a plow tractor? None of its advantages will shine through, and its shortcomings as in the noted fuel usage would indicate a gear tractor to me.
   / How important is rear diff lock on CUT? #148
Cold temperatures are not a problem for an HST beyond the usual getting the engine started and running issues common to all diesels used in the North. The hydraulic oil gets warmed up from being forced through the pumps and drive heads and could even be used to heat the cab if needed.
   / How important is rear diff lock on CUT? #149
In many respects it would be better for my use to have HST but for cost. One alternative to the Foton would have been a Kioti with HST, which also has diff lock, kioti ck35-hst/ but then there was the price difference! Even the occasional scraping in the shuttle is tolerable when compared.
   / How important is rear diff lock on CUT? #150
Don't get me wrong. I am not advocating for HSTs over gear transmissions. I prefer Gears in most situations due to fuel efficiency and time proven designs. But some of the arguments against HSTs have little basis in fact and I prefer to debate the facts not the rumors.
For example I once worked a job where they were cutting out three feet of clay from a two to one cut slope on an interstate highway and back filling it with three feet of seven inch minus ledge. The John deer 750 Hydro. could work up and down the slope in the clay, stop, start , work sideways on a slant and push rock where needed. A Cat dozer with traditional gears and clutches could work straight up and down the slope but not side to side and once it stopped mid slope could not restart up mid slope and had to return all the way to the bottom. On the flat building fills and spreading base courses the Cat did more work per gallon of fuel but on that slope the 750 danced circles around it.
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
