Tractor Sizing How important is rear diff lock on CUT?
   / How important is rear diff lock on CUT? #151
Fair enough, but here the price difference would have been closer to 10K equivalent.
OK, HST is not worth 10K to me. I would have gone gear in that case.
OP here. Just an update...I have 2.2 hours on my EX3200 and already got into a diff lock situation on some rutted ground. No regrets at all. :). Thanks for the advice.
   / How important is rear diff lock on CUT? #153
Trying to visualize. ... I anticipate split braking would have been more appropriate for that. Was steering involved? Side slope?
larry
   / How important is rear diff lock on CUT? #154
QUOTE=onelostdogg;4213774]OP here. Just an update...I have 2.2 hours on my EX3200 and already got into a diff lock situation on some rutted ground. No regrets at all. :). Thanks for the advice.[/QUOTE]
:thumbsup: :thumbsup:
   / How important is rear diff lock on CUT? #155
larry
:stirthepot::hissyfit::muttering: :laughing::laughing::laughing:
   / How important is rear diff lock on CUT? #156
OK, this is an old thread, but for me diff lock has saved my arse more times than I can remember. Mind you my Ford is really small and didn't always have an FEL which has also gotten me out of some slimy, yucky, muck that I should not have ventured into in the 1st place. I've always imagined (right about the time I start sweating bullets) that big heavy, 4wd machines never get stuck and therefore don't need diff lock.
   / How important is rear diff lock on CUT? #157
Imagination will get you in trouble someday. A bigger machine just needs a deeper snow drift or mud hole to get stuck in but there are plenty of big , really big mud holes out there.
   / How important is rear diff lock on CUT? #158
As pointed out, a bigger machine will just get you into bigger problems if you're not considering the limits of your equipment. And it is easier to get into a sticky situation when you think that all the different gadgets will always get you out.
   / How important is rear diff lock on CUT? #159
Very important. Many times, you'll get one wheel out of contact with ground. Tractor won't go without diff lock then.
Ralph
   / How important is rear diff lock on CUT? #160
Ralph
It will go if you have split brakes
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2020 DRAGON ESP...
2020 DRAGON ESP...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
