How hot does it get inside a storage container?
   / How hot does it get inside a storage container? #31
I checked mine when I was sitting in it with a infrared thermometer. The walls were 60 deg Celcius. (140 F) A blast of heat hits you when you open the door. Petrol containers expand to half their size again. I have to leave the lids slightly loose.
I will be fitting a glass sliding door with security screens so I can leave them open in the summer. My containers are dark green.
   / How hot does it get inside a storage container? #32
I have 2 40’s and a 20. The small vents are not enough. If you even cut one 4x4 inch hole in the top of a door and another down low and cover it with a screen and dryer vent cover, you will greatly reduce humidity.
I have rigged up a 5.8 amp draw radiator fan and will be installing it on a 40 that I’ll be storing my tractor in. I’ll use 2 silver panels and a couple of batteries. I bought a temp switch on amazon. I figure I want it running Until temp is under 90F.
   / How hot does it get inside a storage container? #33
Cut vents in the lower 1/4 of doors. Solar power vent in roof on far end keeps it bearable. As mentioned above. a 40 ft was on 500 more than a 20 ft for me. and a Hi top or hi cube is also worth the extra $150 over standard.
   / How hot does it get inside a storage container? #34
Have you considered one of those carport sheds? I have two 18 x 21 with 6 ft. walls. paid $900 for the first one and $1100 for the second one last year. The second one I opted for enclosed side walls, the first one is open all the way around. I have an antique pick up, boat and trailer, two riding mowers, tiller and dump cart under the open shed. I have two riding mowers, two push mowers, 8n ford and room for my mule and four wheeler in the new one. I really want a 30 x 40 metal building on a slab but just can't seem to get it done. I bought a 20 ft single use shipping container about five years ago and put plenty of shelving in it. I open it every day on sunny winter days and of course summer. I gets pretty friggin hot in there. The only ventilation is four little vents on the corners. I considered painting the top with the white mobile home roof coating but that is for another day.
2020 John Deere 75G Hydraulic Excavator (A50860)
2020 John Deere...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A48081)
2015 Chevrolet...
Bad Boy Electric Cart (A50860)
Bad Boy Electric...
JCB 3CX 15HFCE BACKHOE (A51242)
JCB 3CX 15HFCE...
