How High RPM On CK3510
   / How High RPM On CK3510 #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I was just on a Kubota forum on facebook and came a cross a post talking about rpm's. Some ppl mentioned they can run up to 3,000 - 3,500 rpm. On my ck3510 it will only go as high as 2,600-2,700 rpm ( if I can remember correctly)...... Is 2,700 rpm tops normal? The guage goes high but the engine doesn't.
   / How High RPM On CK3510 #2
Sounds about right. My DK 35 will go to around 2700-2800 rpm.
   / How High RPM On CK3510 #3
I can get to about 2900 or so. But, I couldn't when I first got the tractor. The throttle was sticky. I adjusted it where the cable fed through the cowling into the engine compartment. Afterwards, it was smooth and I could reach 2900. I can only reach full throttle with the hand throttle. I guess my foot throttle (gear tractor) isn't adjusted as tightly.
   / How High RPM On CK3510 #4
Engines make rated Hp at certain RPM's, a Kubota with the same rated Hp might have to spin at 3200 RPM's to make rated power. The slower an engine can spin to make rated power, the smoother it should feel.
On my CK3510, I don't usually need more than 2500 RPM's, and only temporarily when lifting or going up hills. Also per advice read on TBN, I also bump the throttle so it is idling at 1500 RPM's in most situations.
   / How High RPM On CK3510 #5
The CK3510 makes rated 34.9 HP at 2600 rpm, I run around 2200-2400 most the time
air compressor (A55758)
air compressor...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
Cart (A55853)
Cart (A55853)
RoGator RG1100C (A55315)
RoGator RG1100C...
