How High RPM On CK3510
   / How High RPM On CK3510 #1
Hdoilcan
Gold Member
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I was just on a Kubota forum on facebook and came a cross a post talking about rpm's. Some ppl mentioned they can run up to 3,000 - 3,500 rpm. On my ck3510 it will only go as high as 2,600-2,700 rpm ( if I can remember correctly)...... Is 2,700 rpm tops normal? The guage goes high but the engine doesn't.
   / How High RPM On CK3510 #2
Sounds about right. My DK 35 will go to around 2700-2800 rpm.
   / How High RPM On CK3510 #3
I can get to about 2900 or so. But, I couldn't when I first got the tractor. The throttle was sticky. I adjusted it where the cable fed through the cowling into the engine compartment. Afterwards, it was smooth and I could reach 2900. I can only reach full throttle with the hand throttle. I guess my foot throttle (gear tractor) isn't adjusted as tightly.
   / How High RPM On CK3510 #4
Engines make rated Hp at certain RPM's, a Kubota with the same rated Hp might have to spin at 3200 RPM's to make rated power. The slower an engine can spin to make rated power, the smoother it should feel.
On my CK3510, I don't usually need more than 2500 RPM's, and only temporarily when lifting or going up hills. Also per advice read on TBN, I also bump the throttle so it is idling at 1500 RPM's in most situations.
   / How High RPM On CK3510 #5
The CK3510 makes rated 34.9 HP at 2600 rpm, I run around 2200-2400 most the time
2016 Caterpillar 289D (A53317)
2016 Caterpillar...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2020 Ram 1500...
2018 Ford Escape (A56859)
2018 Ford Escape...
Red Military Truck (A53422)
Red Military Truck...
