How fast with a canopy?
/ How fast with a canopy? #1
roadhawk
The Pineywoods of East Texas
NH TC40D
The NH I'll be picking up is about 650 miles away and on the ROPS it has a fiberglass canopy. Will that hold up OK on the trailer at highway speeds or will it break, or act like a sail, or?
If I put it down will "down" be far enough to get it out of the wind or will it be acting like a big speed brake?
Do I just need to take it all the way off and figure out a way to put it on the trailer safely, or is it collapsible enough to fit into my Suburban (NH TC40D)?
/ How fast with a canopy? #2
I have Kubota fiberglass canopies and have trailered them about 55 mph for a few miles, but 650 miles? I would take mine off. If you met a big rig running at 70 and you were also running there that could be a big shock wave hitting it.
Can you not place in between the front wheels and rear wheels on the trailer it is on and strap it down?
Just as I was about to hit submit, remembered they hauled my CUT with the canopy on it about 80 miles to me. No interstate so legally 60 was max speed limit.
I haven't seen it yet so that might be the answer.
I didn't consider the suction then poof of a big rig zooming by. Good point.
/ How fast with a canopy? #4
I tow my tractor all the time. When I first got it I pull the tractor on forwards. I now back it on because the weight is better distributed on the trailer and I noted the canopy rides much better. So my simple answer is just back the tractor on and you should have no problems.
Chris
/ How fast with a canopy? #5
I pull my tractor with canopy at highway speeds with no problems.
/ How fast with a canopy? #6
If you want to be sure the canopy won't blow off and you can't back the tractor on, just throw a rope over it and tie the rope ends down to the tractor as an insurance policy.
I know how you feel, I hate driving with a heavy load and being unsure it's properly secured.
/ How fast with a canopy? #7
I do exactly as you have advised but with a flimsy old Cushman golf cart lid. Works great.
/ How fast with a canopy? #8
I just took my T2310, same as TC40DA, with canopy for a 3 hour ride at speeds up to 65mph and there is no problem. When up, the canopy cuts the wind with its leading edge. I also had some concerns originally, but you will have no problem at all.
/ How fast with a canopy? #9
When I had my JD 5203 utility tractor I would throw a ratchet strap over the canopy for safety.
Thanks for all the replies. I'm feeling better about it now.
For those of you that put the "just in case" straps on it, did the bouncing/rubbing cause any damage to the fiberglass?
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
2008 BOBCAT T320 SKID STEER (A62129)
2008 BOBCAT T320...
New Holland WorkMaster 37 (A53317)
New Holland...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
Toro 7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
Toro 7-Gang Reel...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
