How else can I use this control
/ How else can I use this control #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
What I think I was told on here was this was a Power beyond control.
I use this to use the tractor hydraulics to run the back Hoe. Hook up the hoe and bungee the arm down provide fluid to the hoe and not the 3 pth This arm can also be lifted to relieve pressure to release the fitting.
Is there anything else I can do with this valve?
Can I run any implement ?
Say a single hydraulic line dump trailer!!
/ How else can I use this control #2
It looks like a stacked open center aux valve.
You should be able to use it to control a cyl or hyd motor.
I don't believe it is PB. Did the instructions that came with it, say anything about pressure ratings?
Four ports, IN, OUT, two work ports, and a relief valve.
Normally you can't use a valve without PB in a series flow path unless it is the last valve.
You have any idea of brand name or model number.
Contacted the maker of the tractor.
He says its just a hydraulic control.
Hook up the implement and say for a blower chute lift or lower the lever to rotate left of right.
The valve has a red cable tie on one port I match that to the red cable tie on the hoe hose But is that the output or return.
What would happen if the lines were reversed?
/ How else can I use this control #4
You could damage the valve.
/ How else can I use this control #6
If you disconnect both hoses and start the tractor, the pressure line will pump fluid. The other line is the out/return and that line feeds the 3pt.
Your dealer should know about PB and if he did you wrong, then that is between you and him. For instance, if the valves cracks open, is it his fault or yours.
/ How else can I use this control #7
I think what Rasor meant was if he hooks the lines up in reverse, what happens....I believe that what he hooks up would run in reverse. IE a cylinder would expand instead of contract, a motor would run forward when you expect reverse, etc
/ How else can I use this control #9
You can connect work ports any way you want, but the IN and OUT ports need to be correct.
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
