How effective are lawn rollers?
/ How effective are lawn rollers? #1
megotatractor
New Richland, Minnesota
JD 2210
Anyone used a lawn roller to smooth a lawn that is so bumpy it shakes your insides to death? As many have complained my 2210 is a rough rider. I often consider a roller but am not sure if it would help at all. I'd have to do any rolling in the early spring or after a heavy rain as the bumps are like concrete otherwise. My current solution is to let almost all the air out of my HDAP (utility ATV tires) and run at about 5 psi to "float" around the yard. though if I get going too fast it still starts to do a horseybounce thing. And I wonder if it might make my yard bumpier with such low tire pressures since hard tires would seem like they might roll the bumps out a little?? trouble is the hassle of reinflating the tires to use the FEL. It s either a roller or I get a UTV with a towable mower and that would use a LOT more gas than my economical diesel tractor. Maybe a low flying helicopter???
Yes, yes, I know all about X series seat conversions. Sounds easy but doing is another. Not sure how well that seat suspension would hold up on my hillside yard.
/ How effective are lawn rollers? #2
I just got a 48" Agri-Fab lawn roller from Northern Tool and it works well for my purposes - smoothing out dirt after tilling. Unless you use it just after some heavy rains, I don't know that it will do much for established bumps and holes. It will push down mole tunnels or fix frost upheaval but unless you're willing to dig up the soil first I doubt it's a complete solution for you. Depending on the area you need to cover, filling the hole with fresh topsoil and topping with grass seed may be an option. I intend to till up (or box blade or both) bumpy sections of my lawn once my house is built and then roll them flat again, but it will take a year or two before the grass is re-established.
/ How effective are lawn rollers? #3
I have two words for you "Harley Rake". Of course you'll have to re-seed too, but you'll have a smooth lawn. You'll also need to rent a bigger tractor to use it. That's what I'm doing this fall. Full lawn rehab.
/ How effective are lawn rollers? #4
I am sure this is a dumb question ... but what is a Harley Rake?
/ How effective are lawn rollers? #5
It's the quickest and easiest way to smooth out your yard in a short period of time:
Harley
I kind of like the long-term project method better, if I fix everything at once there's nothing left for me to tinker with :)
/ How effective are lawn rollers? #6
I would consider running a chain harrow with the tines down/forward. Each pass will smooth the dirt out slightly. I would think you could do anywhere from 3 to maybe 10 passes in a day without significantly harming the grass. Probably allow 1-2 weeks between the days on which you use the harrow. After 10 passes I think you would see an improvement, and after 20-30 I would think your problem would be solved. Not instant by any means, but should let you level things out without reseeding. Best soil conditions would probably be just slightly moist to just dry enough that soil can move and isn't concrete.
FWIW - without existing grass, a chain harrow will nicely smooth *loose* soil in one or two passes.
Z-michigan that might be worth a try, thanks. I forgot to mention I have 3.5 acres of former pasture. a chain harrow or drag just might help...
/ How effective are lawn rollers? #8
anyone try rolling the lawn with anything larger?
meaning how about a small 4-8 ton vibratory roller (roller in front tires in rear) on wet lawn might that compress and eliminate some of the more abrupt areas?
Just a thought
Dave
/ How effective are lawn rollers? #9
Thought lawn rollers are only used to press new seed into place. Don't think they'd work to even out terrain.
Ralph
/ How effective are lawn rollers? #10
If you get it when wet then a roller will do wonders. A Harley rake is also a good idea. The thing is, it will get lumpy every spring when the frost leaves so I'd invest in a nice heavy roller.
trouble with the Harley rake approach, or grading of any kind is that I have about an acre of the three that is on a hillside and any rain would result in gulleys. I know because I had a lot of trouble with gulleys when I had the old barn buried and tried to seed the area. however, grading seems the only option on the larger whoopdedoos. Northern tool has a 48" x 24" roller which weighs 900 pounds filled. I didn't reallize it was the frost that causes the bumpies, it was a mystery. And so SUPERDUTY is most welcome to bring over his 7 ton vibro whatsit anytime.
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
MF GC2300 fel replaced
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2022 EZ-GO ELITE...
Rogator RG1300C (A63688)
Rogator RG1300C...
