How does weight affect Mahindra ride?
/ How does weight affect Mahindra ride? #1
coffeeman
Platinum Member
Would the 4110 ride a lot better if I had water in wheels?
Decided to do a fast cut on my grass tonite. Most rough spots I know and slow down to idle as I coast thru. Sometime don't slow fast enough. Bounce bounce bounce ....probably cut too fast andshook tractor loose. Now I have a kink in my neck. Funny, I have had one all spring and summer. On and off. I have blamed my pillow; even bought a couple different styles. Also ran and got a new matress; pillow top. Didn't help. Lately, my neck has been ok. Haven't cut or used tractor in 2 weeks. Now I'm wondering. If it is the tractor, will weights help out. Or maybe I just gotta slow down.
Cheers.....Coffeeman
/ How does weight affect Mahindra ride? #2
My 7520 rides better with water in the tires. I have fronts and backs filled.
Brian
/ How does weight affect Mahindra ride? #4
Filling the tires will help with the bouncing. I have RV antifreeze in my fronts and rears.
/ How does weight affect Mahindra ride? #5
Have you tried reducing the air pressure in your tires?
If your PSI is at max or "recommended" levels you can probably improve the ride by lowering it somewhat.
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
