How Does This Work? Voodoo Engineering?
/ How Does This Work? Voodoo Engineering? #21
There's no voodoo engineering going on, you guys just don't have your facts straight. Absolutely zero chance that Kubota is going to lie about their engine performance.
(there are several different versions of their v1505 engine, but it should be this 30.8 HP one in the LX3310)
Y
i misread the tractorgear website , it states torque 84.6 at 2000rpm not 77ftlbs
/ How Does This Work? Voodoo Engineering? #22
Well thats odd. On the Kubota spec sheet, they list the engine as the V1505-CR-TE5-D36R1, which is the turbocharged version that makes 44 HP. But the lx3310 should only has 30.8 HP. Maybe they did confuse something after all.
Does the LX3310 have a turbo?
The 44hp is at 3000rpm, the LX3310 has a rated rpm of 2500 which is part of the reduction, I'd guess the remainder of the lowered HP is through a milder tune to hit a target output/increase longevity. Kind of like they do with the reduced power on a lot of cab and chassis trucks compared to their pickup counterparts.
/ How Does This Work? Voodoo Engineering? #23
Ok so it looks like yes, the lx3310 does have the turbo V1505. Likely de-rated some vs the industrial application engine, indeed. Thats a nice engine....
/ How Does This Work? Voodoo Engineering? #24
I think being lost is the use of the tractor. Regardless of the peak Hp, many people use the tractor PTO. That limits the engine rpm to the number that produces 540 PTO rpm. The designers will have selected the gearing to best use the engine at 540 PTO rpm. Compare ratings at that engine speed.
/ How Does This Work? Voodoo Engineering? #25
According to this calculator:
Calculate horsepower from torque:
Deere: 77.2 ft-lbs at 2500 rpm is: 36.7 Hp (Deere says 37.2Hp/30Hp (PTO))
Kubota: 77.7 ft-lbs at 2500 rpm is: 37 Hp (Kubota says 30.8Hp/27Hp(PTO))
Calculate torque from horsepower (assuming listed Hp is at 2500rpm….but is it?):
Deere: 37.2 Hp at 2500 rpm is: 78.1 ft-lbs
Deere (PTO): 30 Hp at 2500rpm is: 63 ft-lbs
Kubota: 30.8 Hp at 2500 rpm: 64.7 ft-lbs
Kubota (PTO): 27 Hp at 2500 rpm: 56.7 ft-lbs
Interpret away…
I’m confused by how Kubota gets 77.7 ft-lbs at 2500 rpms out of a 30.8 hp engine when math says it takes 37Hp?
Perhaps if 2075 rpms was engine speed for 540 rpm (PTO) and it still produced 77.8 ft-lbs (assuming a flat torque curve) that would equal 30.8 hp, but would you call it a 30.8Hp engine if it produces 37 Hp at 2500rpm?
/ How Does This Work? Voodoo Engineering? #26
Without a complete torque and hp curve from the manufacture all the calculations are just playing with numbers.
Many tractor engines do not develop maximum torque at their rated rpm,
quite often the torque peak will be several hundred rpm below the hp peak.
Many times 540 rpm PTO engine speed will be below the hp peak and above the torque peak.
And don't forget the value of displacement on torque curves.
/ How Does This Work? Voodoo Engineering? #27
Agree Lou. It seems that their horsepower numbers aren’t tied to (qualified by) a particular rpm.
My understanding is Horsepower numbers are often from a “bench test”, done without standard intake, exhaust, pollution (etc..?) systems that engine has when installed on tractor. That is, differences between engine and PTO horsepowers are not just losses in transmission.
/ How Does This Work? Voodoo Engineering? #29
I was comparing the specs between a John Deere 3038E and a Kubota LX3310 and I'm not understanding how these numbers work. If anybody has any ideas please share them.
John Deere 3038E:
Engine Torque at rated speed: 77.2 ft-lbs
Rated Speed/RPM: 2500
Engine horsepower: 37.2
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
Engine Torque at rated speed: 77.7 ft-lbs
Engine horsepower: 30.8
PTO horsepower: 27
Weight: 1,918 lbs
What is it to not understand? The numbers are right there.
/ How Does This Work? Voodoo Engineering? #30
Nobody has gone down this road yet but these are 2 completely different frame sized machines. If you compare like for like the l3301 will clobber the lx3310 all day long. Roughly the same ponies but many more differences. I just had trees cut down and the tree guy brought his lx3310 with his wicked 55 for clean up. I had my l3901 and wicked 55 out and he ran both. Horse power aside he flat out told me my machine would out work his all day long.
As Jeff would say that is mostly to do with weight.
/ How Does This Work? Voodoo Engineering? #33
Higher rated rpm (2800 as opposed to 2500), the torque curve will be on a downward slope at this point so as the engine speed goes up the torque will be going down but the HP will be going up.
I think some of the confusion is that they are listing the HP and torque at the same rpm but because the torque peak is at a lower engine speed its not easy to do a direct comparison.
Looking at 1 or 2 data points doesn't really give you enough info, either post just HP or provide the full curve! Including BSFC
BSFC?
/ How Does This Work? Voodoo Engineering? #37
Some vids to watch. Uses gas engines, but the principles still apply. I wish I could find old Hot Rod articles as there were many that went through these and explained them very well.
/ How Does This Work? Voodoo Engineering? #38
I think of power as being how torque is used over time.
Several people have explained it well.
None of them seem to see any Voodoo in the specs.
But they all agree you can't tell anything from a single number. It needs to be looked at over a range.
/ How Does This Work? Voodoo Engineering? #39
Yup, HP is just work(torque) over time(rpm)
If you know the rpm of the torque peak for both engines you can compare a little bit better, but I think including the tq number at rated rpm is just going to add more confusion when comparing specs.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
