How does a B7800 hour meter work?
   / How does a B7800 hour meter work? #11
I was wondering why my seat would register 12 hours when my hour meter would only register 7. I knew I was working harder than it was reading.
Eric
Okay. Let's change this post to, "The innacurate hour meter that ALL of the tractor manufactures use." How in the hell are we as consumers and owners supposed to accurately measure how many hours our tractors have operated so we can do the required maintenance???????????
The hour meter should start counting the minutes and hours the engine has run when the engine starts running!!!!!!!! How else besides keeping an independant log of the hours used can we know when it's time to do a recomended maintenace operation?????????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / How does a B7800 hour meter work? #13
Muleskinner
Since you don't want to accept the hour meter that runs off the RPMs that your tractor runs at PTO speed, is a good way to keep tract of hours used. I would suggest you purchase and install one of these hour meters. Click Here
That way you can have it both ways. /forums/images/graemlins/crazy.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
   / How does a B7800 hour meter work? #14
Muleskinner,
I can see now that your affliction is that your are severely prejudiced in favor of linear time... /forums/images/graemlins/grin.gif
If the manufacturer of the tractor gives maintenance guidelines in terms of the hour meter on the tractor, they that is the measure you should use. Granted, that hour meter is pretty severe if you use it to time your personal breaks though! /forums/images/graemlins/laugh.gif
   / How does a B7800 hour meter work? #15
The meter has been accurate for maintenance since they started putting them on tractors decades ago.
If you put the engine to heavy service, it needs service sooner. If you put it to light service, it is not as stressed, and will not need service as soon. What they are saying is that 2 hours of light duty work has the same affect on the pistons, rings, bearing, oil ect as 1 hour of hard work.
As a comparison, my truck manual specs out changing the oil at 7500 miles if use is light. For medium work, they recommend 5000 miles between changes. For heavy work use(towing, heavy hauling), the recomend even sooner. So, effectively, 7500 miles empty is roughly the equivilant of 3500 miles of hard work. Just a different method of measuring.
   / How does a B7800 hour meter work? #16
Muleskinner,
</font><font color="blue" class="small">( ...can we know when it's time to do a recomended maintenace operation?????????????? )</font>
Just assume the maintenance intervals are specifying "PTO hours", to coin a phrase. Then all is well and those with "real time" hourmeters are actually performing their maintenance before they need to. /forums/images/graemlins/smile.gif
In all seriousness, I don't think the descrepancy between the two is that major, unless you idle your tractor for long extended periods, and that's bad on a diesel anyway. What is important is that the maintenance is done in a timely fashion and the hours specified are guidelines as to when things should be done.
~Rick
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
