How does a B7800 hour meter work?
/ How does a B7800 hour meter work? #1
Muleskinner
Pioneertown, So CA
2015 KUBOTA B2650ROPS
Does the hour meter start when the engine is running or does the tractor need to be driven to make it register? I did a job that took me four hours today, but the hour meter only registered three hours.
/ How does a B7800 hour meter work? #2
On most CUT's the hour meter reads hour for hour at PTO speed. In other words.......whatever RPM you need to get 540 RPM PTO.
I think /forums/images/graemlins/confused.gif
/ How does a B7800 hour meter work? #3
I think that might be an electric one but not sure. That will add an hour per hour that the key is on.
/ How does a B7800 hour meter work? #4
Muleskinner
Unless <font color="orange"> Kubota </font> changed how the B7800 works from the B2910. The hour meter keeps time by the hours run at PTO speed. If you ran your engine at less than 2600 RPM’s then the full 4 hours will not show on the hour meter.
How are we supposed to keep an accurate count of the actual hours on the tractor if the hour meter only works at full throttle??????????????? I usually run mine around 2000 RPM for most grading work. /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif
/ How does a B7800 hour meter work? #6
The majority of tractors have been using this type hour meter for years.
My new Kioti uses this type hour meter as does my 26 year old John Deere.
/ How does a B7800 hour meter work? #7
<font color="blue"> How are we supposed to keep an accurate count of the actual hours on the tractor if the hour meter only works at full throttle??????????????? </font>
That’s the same way the Hour Meter worked on my 1958 Farmal 340..
/ How does a B7800 hour meter work? #8
</font><font color="blue" class="small">( How are we supposed to keep an accurate count of the actual hours on the tractor...)</font>
I think of it as kinda like an engine odometer. That is, rather than just total running hours, it more closely approximates the total number of revolutions or the total distance the pistons have traveled. In that respect, IMHO, I think it's better this way since it's used to dictate when to change the engine oil.
JMZ
/ How does a B7800 hour meter work? #9
I've wondered how the hourmeter worked since I bought the tractor. Let me make sure I understand, if my PTO speed is 2600 rpm, then if I run the tractor at 1300 rpm, it takes 2 hours running time to record 1 hour on the meter?
/ How does a B7800 hour meter work? #10
<font color="blue"> I think of it as kinda like an engine odometer. </font>
JMZ...I think you are right on there!
<font color="blue"> Let me make sure I understand, if my PTO speed is 2600 rpm, then if I run the tractor at 1300 rpm, it takes 2 hours running time to record 1 hour on the meter?
</font>
8561,
That is exactly the way my B2910 works... /forums/images/graemlins/smile.gif
/ How does a B7800 hour meter work? #11
I was wondering why my seat would register 12 hours when my hour meter would only register 7. I knew I was working harder than it was reading.
Eric
Okay. Let's change this post to, "The innacurate hour meter that ALL of the tractor manufactures use." How in the hell are we as consumers and owners supposed to accurately measure how many hours our tractors have operated so we can do the required maintenance???????????
The hour meter should start counting the minutes and hours the engine has run when the engine starts running!!!!!!!! How else besides keeping an independant log of the hours used can we know when it's time to do a recomended maintenace operation?????????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
/ How does a B7800 hour meter work? #13
Muleskinner
Since you don't want to accept the hour meter that runs off the RPMs that your tractor runs at PTO speed, is a good way to keep tract of hours used. I would suggest you purchase and install one of these hour meters. Click Here
That way you can have it both ways. /forums/images/graemlins/crazy.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
/ How does a B7800 hour meter work? #14
Muleskinner,
I can see now that your affliction is that your are severely prejudiced in favor of linear time... /forums/images/graemlins/grin.gif
If the manufacturer of the tractor gives maintenance guidelines in terms of the hour meter on the tractor, they that is the measure you should use. Granted, that hour meter is pretty severe if you use it to time your personal breaks though! /forums/images/graemlins/laugh.gif
/ How does a B7800 hour meter work? #15
The meter has been accurate for maintenance since they started putting them on tractors decades ago.
If you put the engine to heavy service, it needs service sooner. If you put it to light service, it is not as stressed, and will not need service as soon. What they are saying is that 2 hours of light duty work has the same affect on the pistons, rings, bearing, oil ect as 1 hour of hard work.
As a comparison, my truck manual specs out changing the oil at 7500 miles if use is light. For medium work, they recommend 5000 miles between changes. For heavy work use(towing, heavy hauling), the recomend even sooner. So, effectively, 7500 miles empty is roughly the equivilant of 3500 miles of hard work. Just a different method of measuring.
/ How does a B7800 hour meter work? #16
Muleskinner,
</font><font color="blue" class="small">( ...can we know when it's time to do a recomended maintenace operation?????????????? )</font>
Just assume the maintenance intervals are specifying "PTO hours", to coin a phrase. Then all is well and those with "real time" hourmeters are actually performing their maintenance before they need to. /forums/images/graemlins/smile.gif
In all seriousness, I don't think the descrepancy between the two is that major, unless you idle your tractor for long extended periods, and that's bad on a diesel anyway. What is important is that the maintenance is done in a timely fashion and the hours specified are guidelines as to when things should be done.
~Rick
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2017 Chevrolet Malibu Sedan. (A61574)
2017 Chevrolet...
2015 Kawasaki Mule 4x4 Utility Cart (A61572)
2015 Kawasaki Mule...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
