How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #1
MechanicalGuy
Platinum Member
Beautiful South
Kubota mx5200
I can't find this online anywhere and i dont have a dealer close to look at them. Do they use bevel gears to turn and transmit power simultaneously?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #2
This should answer your question (answer is yes):
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #4
I guess my answer of with the steering wheel would of been incorrect. :laughing:
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #5
Unless I'm missing something, that diagram just shows the front wheel drive and doesn't show the steering.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #6
The steering mechanism is a rack and pinion, with the rack mounted on the front axle housing. I can’t see details in the previous post, but it looks like power is transferred through a series of bevel gears and shafts. The steering rotated along the axis of one of these gear / axle shafts so the bevel gears are always in contact to transfer power.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #7
You're sure it doesn't use an hydraulic cylinder and a orbitrol steering valve instead of a rack and pinion?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #8
KIOTI Tractors use an Orbital Steering Valve and single/dual hydraulic cylinders for steering, depending on model. No rack and pinion on KIOTI Tractors.
Hope this helps.
It answers what I was asking. The drive mechanism isn't achieved through u-joints or cardovan joints.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #10
Yup, you’re probably correct. Looks like a rack at first glance, but hydraulic would be a likely possibility on a low speed machine.
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
