How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #1
MechanicalGuy
Beautiful South
Kubota mx5200
I can't find this online anywhere and i dont have a dealer close to look at them. Do they use bevel gears to turn and transmit power simultaneously?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #2
This should answer your question (answer is yes):
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #4
I guess my answer of with the steering wheel would of been incorrect. :laughing:
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #5
Unless I'm missing something, that diagram just shows the front wheel drive and doesn't show the steering.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #6
The steering mechanism is a rack and pinion, with the rack mounted on the front axle housing. I can’t see details in the previous post, but it looks like power is transferred through a series of bevel gears and shafts. The steering rotated along the axis of one of these gear / axle shafts so the bevel gears are always in contact to transfer power.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #7
You're sure it doesn't use an hydraulic cylinder and a orbitrol steering valve instead of a rack and pinion?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #8
KIOTI Tractors use an Orbital Steering Valve and single/dual hydraulic cylinders for steering, depending on model. No rack and pinion on KIOTI Tractors.
Hope this helps.
It answers what I was asking. The drive mechanism isn't achieved through u-joints or cardovan joints.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #10
Yup, you’re probably correct. Looks like a rack at first glance, but hydraulic would be a likely possibility on a low speed machine.
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA SK 72" HYD BRUSH CUTTER (A57192)
UNUSED INDUSTRIAS...
2016 VOLVO L45H WHEEL LOADER (A52707)
2016 VOLVO L45H...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
