How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #1
MechanicalGuy
Platinum Member
Beautiful South
Kubota mx5200
I can't find this online anywhere and i dont have a dealer close to look at them. Do they use bevel gears to turn and transmit power simultaneously?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #2
This should answer your question (answer is yes):
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #4
I guess my answer of with the steering wheel would of been incorrect. :laughing:
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #5
Unless I'm missing something, that diagram just shows the front wheel drive and doesn't show the steering.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #6
The steering mechanism is a rack and pinion, with the rack mounted on the front axle housing. I can’t see details in the previous post, but it looks like power is transferred through a series of bevel gears and shafts. The steering rotated along the axis of one of these gear / axle shafts so the bevel gears are always in contact to transfer power.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #7
You're sure it doesn't use an hydraulic cylinder and a orbitrol steering valve instead of a rack and pinion?
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #8
KIOTI Tractors use an Orbital Steering Valve and single/dual hydraulic cylinders for steering, depending on model. No rack and pinion on KIOTI Tractors.
Hope this helps.
It answers what I was asking. The drive mechanism isn't achieved through u-joints or cardovan joints.
   / How does a 40-50 hp kioti tractor steer? What kind of steering knuckles does it use? #10
Yup, you’re probably correct. Looks like a rack at first glance, but hydraulic would be a likely possibility on a low speed machine.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
Toyota Forklift (A55973)
Toyota Forklift...
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2002 Henderson FSP Sandspreader Attachment (A55973)
2002 Henderson FSP...
2020 DRAGON ESP...
