How do you remove these fasteners?
/ How do you remove these fasteners? #1
bitternut
Western NY
2000 John Deere 5210 mfwd, John Deere 350C Crawler
I am installing some Husky mud guards on my 2009 Silverado 2500HD and need to remove a couple of fasteners on the fender liners. Two of them are regular hex head screws but the other is a type that I am not sure of how to remove. I have to remove one of them for the install of the guards and I would like to not destroy the fastener if possible. Any suggestions on how this could be done?
/ How do you remove these fasteners? #2
Those fasteners look like plastic one way - one use. Some good hardware stores have bins with some or you can get replacements at the dealer.
/ How do you remove these fasteners? #3
like shvl73 says they are probably single use. But do try to remove them if you see where that slot on the head is.
Use a flat head and pry the 2 pieces of plastic apart they come apart easy. You may be able to reuse them you won't know until till they come apart.
I am sure most auto parts store will carry something that will work for you. it doesn't have to be the exact same. Just fit into the whole without to much wiggle room.
Shane
/ How do you remove these fasteners? #4
As the other have said. They work like rivets. Pop the center out the pry out the outer part. When they go back together the center makes the outer expand and hold it together.
Chris
/ How do you remove these fasteners? #5
I have used the regular christmas tree fasteners to put mud flaps on. They are much more secure, are easy to get and usually can be reused. Try it if you are going to the store anyways.
/ How do you remove these fasteners? #6
It was originally a Toyota fastener for the splash shield on front fenders.
Insert a flat screwdriver in one of the slots and pop the center up about 1/2" and then pry out the entire fastener with a screwdriver or putty knife.
They are reusable 90% of the time, the rest of the time they break.
Any body shop will have these if you need any.
Thanks folks for the replies. I have had mixed results removing them in the past and thought that there might be some sure fire method. Usually I can get them out pretty easy but once in a while I have run into a stubborn one. Wondered if there might be a better way that I did not know about.
/ How do you remove these fasteners? #8
You can spray some WD-40 on it, helps to lube up the plastic. Usually there is dirt between the center part and the outside part. The WD will help out.
/ How do you remove these fasteners? #9
You can purchase a tool to help pop them out. Looks like a wide bladed screwdriver with a "V" shaped notch but works better than a standard screw driver. NAPA carries a good selection of plastic fasteners at a good price if you need to replace any.
/ How do you remove these fasteners? #10
Looks like a standard trim fastener to me. They kind of work like a toggle bolt. On the other side the outer part expands out when the center is pushed in. Pry out the center part (you usually don't have to remove it completly) and the main body should pry out easily.
/ How do you remove these fasteners? #11
I just put mudflaps on our Suburban. Had to do the same thing. I was able to get all of them out by just putting a medium flat screw driver under the center and prying out. That usually pulled both pieces out. Incidentally, if you are installing GM mudflaps (I did), you won't have to reuse those. The flaps themselves inlcude the body clips and the additional bolts needed to do the install.
/ How do you remove these fasteners? #12
Or you can just pry on it till it breaks and then try and find a replacement that will work afterward.
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
Vandale Feed Wagon (A65640)
Vandale Feed Wagon...
6' 3-Pt Disk (A66285)
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
