how do you remove the front pulley
   / how do you remove the front pulley #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
My father in Law is working on a Allis Chalmers B and cant get the front pulley off
is it just a nut and then a puller? or is there more to it?
   / how do you remove the front pulley #2
look behind pulley itself, you will see a large setscrew with a locking nut on it. Loosen nut, then remove bolt, pulley will now pull off with a bit of effort. when installing it back on, be sure point of bolt is going down into the hole machined in the crank
   / how do you remove the front pulley #3
hope it comes off easier than the one on my farmall C did.. it BROKE! and then I had to split the hub!!
   / how do you remove the front pulley #4
If those manufacturers had known about the QD split bushing and sheave system we wouldn't be having these problems. Oh, maybe they hadn't been invented when those old tractors were made.
They may still be a replacement for the original even though they have a key way and your shaft may not have a key seat. If installed according to the directions the bushing grips the shaft so tight the key isn't really needed.
http://www.emerson-ept.com/eptroot/climate/pdfs/HVAC-05 Catalog LR p150-157.pdf
Update... he had to ruin the pulley to get it off it was badly rusted
where can I find a new pulley and an engine rebuild kit?
   / how do you remove the front pulley #6
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
Deere 310L (A53317)
Deere 310L (A53317)
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
