how do you remove the front pulley
   / how do you remove the front pulley #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
My father in Law is working on a Allis Chalmers B and cant get the front pulley off
is it just a nut and then a puller? or is there more to it?
   / how do you remove the front pulley #2
look behind pulley itself, you will see a large setscrew with a locking nut on it. Loosen nut, then remove bolt, pulley will now pull off with a bit of effort. when installing it back on, be sure point of bolt is going down into the hole machined in the crank
   / how do you remove the front pulley #3
hope it comes off easier than the one on my farmall C did.. it BROKE! and then I had to split the hub!!
   / how do you remove the front pulley #4
If those manufacturers had known about the QD split bushing and sheave system we wouldn't be having these problems. Oh, maybe they hadn't been invented when those old tractors were made.
They may still be a replacement for the original even though they have a key way and your shaft may not have a key seat. If installed according to the directions the bushing grips the shaft so tight the key isn't really needed.
http://www.emerson-ept.com/eptroot/climate/pdfs/HVAC-05 Catalog LR p150-157.pdf
Update... he had to ruin the pulley to get it off it was badly rusted
where can I find a new pulley and an engine rebuild kit?
   / how do you remove the front pulley #6
Sheets of Tin (A57149)
2016 Bobcat S740 Skid Steer (A57148)
2016 Bobcat S740...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2003 Mercedes Benz CLK 350 (A57148)
2003 Mercedes Benz...
2259 (A58376)
2259 (A58376)
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
