How do you refurbish an old implement?
/ How do you refurbish an old implement? #1
Laminarman
Upstate NY
TC40DA
I'm looking for an old but very workable corn planter, and thought it might be fun to refurbish one. I'm waiting for a reply from Ken Sweet on this item. How does one go about getting old "crud" and rust off a 40 year old planter, paint it all shiny green (or black or whatever)?? Do you sandblast the whole 'dern thing? I know a lot of photos say "very fine working order" but those planters look like they've seen WWI and II. I have a 6hp air compressor so don't know if that will let me bead blast very well.
/ How do you refurbish an old implement? #2
I've never done an implement, but I like to restore tractors, I presume the process would be pretty much the same. Take it apart, hand sand or sand blast, pound out the dents, fill in the rust holes with weld or bondo or weld in some new metal, replace the worn parts with new (it helps to know a good machinist who can make stuff that is no longer available), prime, paint and assemble. Good as new? But as the lovely Mrs_Bob is known to say "what are those 'extra parts' for . . . don't they belong somewhere on that tractor?" Uh, yea, I suppose so!
/ How do you refurbish an old implement? #3
That just goes to show the engineers did not need to put all that junk on there in the first place /forums/images/graemlins/grin.gif
/ How do you refurbish an old implement? #4
I love restoring old implements as much as I do reworking old tractors. I'm just finishing a 2-row cultivator. It was a rust-ball when I started. My plow I use for the garden was much the same way. I've done a couple 2-row planters also.
Start by dismantling them. Take a wire wheel (on a 4-1/2" grinder ?) to as much as you can, and/or sandblast. Straighten parts that are bent. Replace (if possible) any parts that are too badly damaged. I like to prime and paint while everything is apart. Re-assemble, and shoot a final coat of paint. Decals are available for most John Deere (as that is what I have experience with) equipment, and I'd assume they're available for other brands also. (I get MOST of my decals through K&K TRACTOR, in Shelbyville, Indiana)
There's a great deal of satisfaction in restoring anything old. Add to that, there's a great many older implements that just aren't available new anymore (i.e. plows...)
As soon as I get the bugs worked out, and can post pictures on here, I've got several completed projects I'd like to show off. Plows, a disc, a couple 2-row planters, cultivators, a baler, even an old pull-type Deere combine.
And half the "fun" is the search for replacement parts for all the old stuff....
/ How do you refurbish an old implement? #5
You can also take the rust off with a battery charger and some washing soda in water. I ( and others) have put some posts up on this before - do a quick search on rust removal. I have a couple Oliver parts cooking in the garage right now. It really works! /forums/images/graemlins/smile.gif
/ How do you refurbish an old implement? #6
</font><font color="blue" class="small">( You can also take the rust off with a battery charger and some washing soda in water. I ( and others) have put some posts up on this before - do a quick search on rust removal. I have a couple Oliver parts cooking in the garage right now. It really works! /forums/images/graemlins/smile.gif )</font>
Electraulisis..... I've done that a few times also. Works good in some cases. Another way I've used to clean a few parts is to "hot tank" them. A buddy runs a radiator repair shop. We've dropped a few nasty parts in his caustic soda tank and cleaned them right up. Takes paint off quick! You just don't want to forget and leave something on too long, for it won't be there when you go back to get it... /forums/images/graemlins/crazy.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/shocked.gif
Thanks guys. I look forward to trying my hand at it.
/ How do you refurbish an old implement? #8
I don't know what you'll find with your planter, but I acquired an old "Herd" broadcast seeder that had been out in the weather for many years with no use and the works were just about solid rust and grime, even though the hopper was OK as it was galvanized. I was excited to find that parts are still available and that model is still being sold, but after I spent a day or two taking it apart using about three cans of penetrating oil I found that it works and I don't need parts yet. For me, if I can make it work, it's refurbished. Good luck with your planter.
/ How do you refurbish an old implement? #9
Laminarman; I'm refurbishing a 6' landscape rake right now. I don't know what brand it is. It sat unused for 10 years out in the weather! I had to grind the nuts off all the tine bolts. The tines are in good shape. The only real bad rust was the tine mounting crossmember. So far, I've disassembled it and scraped the rust off as much as I could, then painted some rust converter on it. According to the label, I have to let it dry for 3 days before I can paint it. I got 34, 3/8X1 1/4" stainless bolts, washers, and self locking nuts to remount the tines. Anyone want photos of this? It seems to be a pretty wellmade rake, I guesstimate about 300lbs in weight. /forums/images/graemlins/grin.gif
I've also picked up a 6' disc harrow from RonJHall. It's in better shape than the rake was, but I also plan on repainting it too.
/ How do you refurbish an old implement? #10
I've used electrolysis and wire brushing. No matter what you do, it's a good idea to apply some Rust Reformer (Rustoleum brand) or Rust Extender (NAPA brand) to the metal/rust. It reacts with rust (iron oxide) and turns it iron sulphide black. ANY surface that gets worn to bare metal can be treated with this material to keep it from rusting further. I did my snow plow a couple years ago. It still hasn't rusted where supposedly bare metal is showing. You can paint over the stuff; use a primer first.
Ralph
/ How do you refurbish an old implement? #11
Re: sand blasting....
Last summer I refurbished a 70's era Jacobsen fairway mower. I started out using chemical stripper, but its a mess and bad for both the user and the environment. I too did not have enough compressor to sand blast, but I did have a new pressure washer. In doing a little surfing research I found a sandblasting attachment to the pressure washer that proved to be just the ticket.
The water in the pressure washer knocks down the dust that you would have with dry blasting and I think it improves the efficiency. You just replace the nozzle of your pressure washer with the attachment, stick the pick up tube in a bag of sand and blast away.
The attachment isn't cheap, but compared to getting set up for dry blasting, it is a real bargain. As I remember it was around 125.00.
Wow..that's a beauty of tiller!! /forums/images/graemlins/wink.gif
/ How do you refurbish an old implement? #14
He even went to the point of putting "NEW PAINT" in bold in the listing, as if the overspray on the ground around it wasn't enough clue.
Then, for some reason, he saw fit to move it just enough that you can see the unpainted spots on the wheel! /forums/images/graemlins/grin.gif
Funny, he didn't think it worth mentioning that there were some broken tines. /forums/images/graemlins/confused.gif
Let's see now, where is that list of "sellers whose ads I want to block"...?
/ How do you refurbish an old implement? #15
I just picked up a F160 Herd Broadcast Seeder at an auction today. This one was also frozen up with some rust and a lot of crud. Was able to get it turning this afternoon but have not put it on my tractor yet. Have seen the Herd website but don't have an "owner's manual" or any such thing. Can you tell me anything about it? Do you have the same one?
/ How do you refurbish an old implement? #16
We have used most of the methods mentioned above. It really depends on what we are selling and how much we will ask for it. There is a point at which the customer will not pay for the added value. I suspect that most of the implements reworked (From the Heart) could not be purchased for Cost + time and material??. I bought a 1959 430W 2 cyl JD for $2500 and sold it for $6500 4 years later. Sounds like a good profit margin until we add the time and material. Cleared about $1000 profit on the unit--Ken Sweet
/ How do you refurbish an old implement? #17
</font><font color="blue" class="small">( We have used most of the methods mentioned above. It really depends on what we are selling and how much we will ask for it. There is a point at which the customer will not pay for the added value. I suspect that most of the implements reworked (From the Heart) could not be purchased for Cost + time and material??. I bought a 1959 430W 2 cyl JD for $2500 and sold it for $6500 4 years later. Sounds like a good profit margin until we add the time and material. Cleared about $1000 profit on the unit--Ken Sweet )</font>
I did that with a plow last fall. I decided it was "just what I needed" for a tractor I restored. I spent over $500 on parts, another $40 on paint, decals added yet another $40. Then I spent around 40 hours dis-assembling it, sandblasting, priming, painting, and re-assembling. When I was done, I hade over a grand in a plow that is worth MAYBE $600... But it looks BETTER than a new one did 50 years ago.
Then I find out it's not nearly enough plow for the tractor. /forums/images/graemlins/crazy.gif
And there's NO WAY I can sell it for even "break even price".
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2024 ROADCLIPPER HDT207 T/A 22FT TILT TRAILER (A59914)
2024 ROADCLIPPER...
