How do you Poo?
/ How do you Poo? #21
re: What Kind Of Septic System Do You Have?
Standard 1500 gallon tank and two fields, switch annually. Closest sewer is, ah, geeeez, I have no idea. And, while you didn't ask, yes, we have our own water too. 95' down. Beautiful sand/gravel, the best water in the world.
/ How do you Poo? #22
We're on a septic system with an outhouse for a back-up. During power outages, when we have no water from the well to flush, we use the outhouse. Saved us a couple of times....Regards, Mike
Now I know why I built a 3 bathroom house for the two of us. :laughing:
/ How do you Poo? #23
Pressure septic field. We could not go the conventional gravity septic system due to being next to the creek and clay ground. Cost lots of money :mad: to do the pressure field.
/ How do you Poo? #24
Septic field. On a well also.
/ How do you Poo? #25
septic--- Rural water Rural water is almost the same as City Water, just no fire protection.
/ How do you Poo? #26
Septic, no drain field, its an aerobic unit.
/ How do you Poo? #28
Septic, pump to drain field.
/ How do you Poo? #29
How do you Poo?
sit and strain, sit and strain :p :laughing: :laughing:
Just wondering what percentage of TBN readers use septic systems versus connected to a municipal sewer system.
I installed our septic it is engineered to run up hill. Just saying all crap doesn't roll down hill :laughing: It has 2 tanks, 1 is 1500gal, this is pumped to the another 1000gal tank, then it flows into a leach field.
To help keep this politcal:drool:, I have planted little men in black suits in the leach field. I figure when they grow up they'll be full of_____ and can be perfect for politics. :laughing: :laughing: :laughing:
/ How do you Poo?
So if the electric goes out, (No, I won't make the easy joke:))
you have to go to generator?
/ How do you Poo? #31
Septic, leech field
/ How do you Poo? #32
Septic w/ drain field. When we built the barn/workshop we put in a separate holding tank w/ a grinder pump to feed the house septic tank. It was either that or a complete separate septic system for the building. We didn't have the space for a separate drain field that we couldn't drive equipment over so we went with the tank/pump option.
/ How do you Poo? #33
Septic here.
This is really a political question, and the researcher is a plant from the feds. There will be a push for equal poo.
I'm not much for the government redistributing wealth, but they can redistribute my poo all they like...:laughing:
/ How do you Poo? #34
Re: What Kind Of Septic System Do You Have?
Septic and gravity leech field. Private well.
Dave.
/ How do you Poo? #35
It goes from a regular septic tank into the 800 gal pump tank. As it pumps from near the bottom it has room for about 600 gal of real good stuff :D before it would over flow. As we are on well (near the shop, 250 ft from the house) we do not have power for water. So if you flush a few times it will not come near to filling the pump tank. Had the electrician out yesterday, he is going to put in a plug (220 volt at the breaker panel) for our 1/2 HP pump that is in our 2,000 gal storage tank. We can then plug into a generator and have water. :thumbsup:
/ How do you Poo? #36
Drip irrigation septic.
/ How do you Poo? #37
If there's no drain field, where does the effluent go?
It sprays out as pure water just like the municipal sewer systems. Essentially, those of us on aerobic systems are a municipal sewer system of one. I have two pop-up sprinklers that water my grass. As long as the air pump works to keep the little bacteria bugs happy and well fed, there is no odor at all in the spray except for a slight chlorine smell from the tiny bit of "insurance" chlorine added to the water. The nice thing about aerobic is no leach field problems. The bad thing is the state requires an annual service contract, so it costs me about $225 annually or about $75 per inspection and cleaning every 4 months. My aerator motor runs continually and that is an electric expense just like my well pump. The motors last about 6 to 8 years and have to be replaced because of shot bearings, cost: $400. My initial cost for the system was $5500 back in 2001. I also had to pay an engineer to approve the layout and $400 to the county for an inspection of the installation.
In addition, I guess I should say I have a gray water system because our laundry water is just drained out on the ground. So essentially, I have an aerobic system and a gray water system.
/ How do you Poo? #38
Jinman hit it on the head, with Aerobic, it just runs out into a gulley near my house. It's pretty clean coming out. With mine, it only gets checked once a year, and yeah, it eats up some electricity every month. My motor costs about $200 to replace.
/ How do you Poo? #39
I still don't understand why the dog can poo in the yard, politicians can talk poo,throw poo, spread poo, feed us poo, but I cannot poo in the yard myself. In fact, in Iowa it is not legal to have an outhouse and all residences must have indoor facilities.
/ How do you Poo? #40
septic, wouldn't want it any other way, cause the alternative means there are just too many people around.
And I had to go and read the privacy thread, that tattoo comment was some kind of funny. :D
KING 4R CHISEL RIPPER BEDDER (A63291)
KING 4R CHISEL...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
