How do you light your bonfires?
/ How do you light your bonfires? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Just intrigued as burning season is getting near. For those of you who can, what is your technique? For me, it consists of a gallon of diesel / old oil mix in a sprayer, a propane weed burner and a leaf blower.
/ How do you light your bonfires? #2
I just use some diesel sprayed on newspaper or cardboard placed in the bottom/center of the pile as best as possible.
I light with a BBQ stick and it always goes from there with no problems.
MoKelly
/ How do you light your bonfires? #3
gather up a bunch of dry stuff, or as much as I can find.
Attempt to make a sorta "cave" area on the windward side of the pile big enough to fit some pizza boxes, paperboard etc in. light with a torch stuff dry stuff in around/ontop.
I have been known to get out the leaf blower on occasion but only when the pile was really wet and i was short dry material to start.
/ How do you light your bonfires? #4
Starting a bonfire is a good time to practice your fire starting skills. Get two sticks and rub them.
I use a propane brush burner to start mine.
/ How do you light your bonfires? #5
This is the only good use for ethanol gas.
/ How do you light your bonfires? #7
Diesel is hard to beat, I don't see a down side. Last weekend, in the rain, I lit a very large wet brush pile with a quart of diesel and a BIC lighter.
/ How do you light your bonfires? #8
LOL ... but, actually, I do use gas. Sometimes I will also presoak with old hydraulic oil or old diesel.
/ How do you light your bonfires? #9
Diesel fuel and flares.
/ How do you light your bonfires? #10
Old stale gas mixed with used motor oil and a flaming arrow (w/pine tar)...!
/ How do you light your bonfires? #11
Flares work great bonfire / wood furnace.
/ How do you light your bonfires? #12
Back in Jan. I had a good size pile of branches to burn up. Still having hot coals from the night before in the wood stove, I cleaned out a good portion of them out into a good size metal container and carefully carried it to the pile and dump it on. In no time the pile was burning.
/ How do you light your bonfires? #13
Rolled up newspaper and a match.
/ How do you light your bonfires? #14
I pour a little diesel around the pile, then use my flamethrower (AKA propane torch).
/ How do you light your bonfires? #16
Old motor oil
-recently have also used a leaf blower to "help" it along. Works great.
/ How do you light your bonfires? #18
I use used oil hyd fluid or ATF & have old gas that I clean parts with mixed in. Use pump up sprayer and it is one great flame thrower. Just to make sure there is not too much gas to oil ratio, the spray is great & can really go FAST! I also save up old bills, Government Warrants, subpoena or Jury Duty summons or other paper to toss in :/ :D...
M
/ How do you light your bonfires? #19
I just pile up some dry stuff a couple feet high, put some dry leaves at the bottom and stick a match to it.
I'd stay away from gas.... thought I'd try it as a teen to light a pile of wet oak leaves. Poured a large cup of gas on the pile and walked back to the house to get a match. Gone maybe 1 minute. When I threw the match onto the pile all I remember seeing was a very bright flash followed by (the best way I can describe it) a brief vision of a leaf pile X-ray. I distinctly remember light coming from around the edges of each and every leaf. Then I noticed the WOOF sound, the smell of burning keratin ( my eyebrows and hair ) and I was laying on my back with burning leaves falling on me. Never did that again.
:eek:
/ How do you light your bonfires? #20
Only time I've used gasoline was some chainsaw gas once when it was so cold I couldn't get raw diesel fuel to light!
Starting a fire with gasoline is way too dangerous! Experience from 29 years as a firefighter!
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2022 EZ-GO ELITE...
Used Landpride GR1525 Stump Grinder
Used Landpride...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2022 EZ-GO ELITE...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
