How do you adjust reliefs
/ How do you adjust reliefs #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Not that I need to, but should the need arise, what is the proper way to adjust pressure relief valves?
/ How do you adjust reliefs #2
Without question, the use of a gauge of the proper capacity in the protected circuit is a requirement for correct adjustment, and the system has to be operated so as to develop relief pressure. Beyond that, some relief valves are shimmed, some have screw adjustment, and some are set and staked at the factory and are considered non-adjustable (although they usually are, one way or the other).
As your question was generic in nature, the answer can't be more specific. If you have a particular valve in mind, you should say so.
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A65563)
1996 International...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
(1) HD 24ft Free...
