How do you adjust reliefs
/ How do you adjust reliefs #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Not that I need to, but should the need arise, what is the proper way to adjust pressure relief valves?
/ How do you adjust reliefs #2
Without question, the use of a gauge of the proper capacity in the protected circuit is a requirement for correct adjustment, and the system has to be operated so as to develop relief pressure. Beyond that, some relief valves are shimmed, some have screw adjustment, and some are set and staked at the factory and are considered non-adjustable (although they usually are, one way or the other).
As your question was generic in nature, the answer can't be more specific. If you have a particular valve in mind, you should say so.
20ft Phelan Lowboy Trailer (A65563)
20ft Phelan Lowboy...
Kubota L3901HST
Kubota L3901HST
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
Power King Tractor
Power King Tractor
20ft Driveway Gates (A65579)
20ft Driveway...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
