How do I get this boulder out of this hole?
   / How do I get this boulder out of this hole? #12
Dig a path down so you can drive down to the rock, then drag the rock up the hill.
   / How do I get this boulder out of this hole? #13
I've done this when working by hand and shovel only.
Roll it as far to one side as you can. Fill in under it.
Roll it to the other side as far as you can. Fill under it.
Repeat until it is out of the hole.
Bruce
   / How do I get this boulder out of this hole? #14
This is what I did digging out a similar rock with a old Ford loader/hoe. Once the ramp was dug, I rolled the rock onto a '58 Chrysler hood (heavy metal) and slid the rock on its sled. It still took 2 tractors in tandem to drag the sled. If I had that rock today, I would get my friend with his Deere 460D to easily get it moved.
   / How do I get this boulder out of this hole? #16
Assuming 7' by 5 or 6' that boulder probably weighs in excess of 20,000lbs. Big tow wrecker with crane and sling.
   / How do I get this boulder out of this hole? #17
Bruce
I've lifted a couple of good sized stones out of the ground this way. Long levers snd chain slings to gain an inch with each tilt. It took a few days of steady work before one of the stones was up on level ground and "dragable", using small diameter logs for skids.
   / How do I get this boulder out of this hole? #20
Since you have an excavator this seems to me a workable solution. You may have to winch it with a double or triple line pull using the excavator as an anchor.
Once out of the hole how do you plan or relocating it?
I managed to ramp mine onto the bed of my pickup once home my wife showed me where to put it. I tied it to a tree and when driving out from under it it broke both hangers on the tail gate, and that is where it sits today, not exactly where it was supposed to be but close enough.
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2021 Caterpillar 272D3XE High Flow Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
