How Do I Fix This
/ How Do I Fix This
Gary Fowler said:
I would be happy to fix that for you for free. Load here up and bring it on by. Have to furnish your own paint though. I forgot to pick up a can today when I was at the dealer. Anyone know of a matching spray can color for the LS's. I have a few spots that are flaking off on the FEL mounting an I likely knocked off some with the chains today when trailering it home.
Gary, My dealer does have the factory paint in a spray can, but I asked her to check to see if they have it in some type of touch up bottle. I'll let you know.
Randy
Sent from my iPad using TractorByNet
/ How Do I Fix This #22
i'd grind the paint, bend to place.. and then arc weld.. then chanse the threads if needed.. clean up.. prime and paint to match after a lil grind.
wouldn't think anythig of it.
put ground clamp as close to work as possible., etc.
have done MUCh welding on auto's and tractors. I do not routinely remove the alt / bat.. etc..
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2000 Volvo WG Tri-Axle Dump Truck (A59230)
2000 Volvo WG...
Vermeer Vac trailer (A60352)
Vermeer Vac...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
