How do I fix this - Rounded out holes
   / How do I fix this - Rounded out holes #41
If no zerk there, this is a good time to remedy that.
prs
Maybe some better pictures of the joint would show why there are no zerks. There's two tabs with holes in them. A bolt runs through the tab, through a sleeve(as I recall) and through the other tab. Its supposed to be tight so the bolt can't turn inside the tabs. The sleeve and/or bolt goes inside a ball joint, like the balls on the rear arm of a 3pt hitch. The ball joint is welded to the end of the hydraulic cylinder. There is nothing to grease on the tab or bolt as its not supposed to move. Every 8 hours of operation, we are supposed to spray down the ball joint with super lube or teflon or lithium grease.
We need a close-up picture of a good in-tact joint to explain it better.
   / How do I fix this - Rounded out holes #42
Dang smart phones.
Fat fingers, small keys, and auto-correct. Always comes up with something interesting doesn't it.
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
