How do I fix this - Rounded out holes
   / How do I fix this - Rounded out holes #41
If no zerk there, this is a good time to remedy that.
prs
Maybe some better pictures of the joint would show why there are no zerks. There's two tabs with holes in them. A bolt runs through the tab, through a sleeve(as I recall) and through the other tab. Its supposed to be tight so the bolt can't turn inside the tabs. The sleeve and/or bolt goes inside a ball joint, like the balls on the rear arm of a 3pt hitch. The ball joint is welded to the end of the hydraulic cylinder. There is nothing to grease on the tab or bolt as its not supposed to move. Every 8 hours of operation, we are supposed to spray down the ball joint with super lube or teflon or lithium grease.
We need a close-up picture of a good in-tact joint to explain it better.
   / How do I fix this - Rounded out holes #42
Dang smart phones.
Fat fingers, small keys, and auto-correct. Always comes up with something interesting doesn't it.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Ramfan Gas Powered Ventilator (A56860)
Ramfan Gas Powered...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
HiSpec ST205/75R15 Tires (A56860)
HiSpec ST205/75R15...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
