How difficult to operate a mini excavator
   / How difficult to operate a mini excavator #61
There have been many an acre cleared by dozers. Many had a v plow with cage for protection that sheared off trees. Followed by another cat with a bush rake blade that piled the downed trees into windrows. Followed another cat pulling a Rome plough.
   / How difficult to operate a mini excavator #62
several years ago I picked up a bobcat 430 mini, biggest issue was no cab, after 8 years I traded it for a bobcat e32, very capable machine and with a ripper tooth gets trees out easily, way better than with a bucket, clean up with the skidsteer
I have a dozer its old Cat D2 but sure pushes the down trees into rows with ease
   / How difficult to operate a mini excavator #63
I have about 3 acres that I want to clear on my property. Quite a few big pines and sweet gums but a lot of 4-6 inch trees that I don't want and lots of smaller privet and brush.
I don't want to get it mulched because it leaves a lot of splintered stumps that will re sprout back out and difficult to mow because of the stumps. I was thinking about renting a mini excavator. Could dig up the smaller trees and brush and if I did have any regrowth it would be easier to mow.
I thought about buying a used mini ex and then selling after I'm finished but I saw that I can rent one for $2000 per month. Problem is I have no experience operating anything like this. Can someone tell me what the learning curve is to use one of these to clear land as I described. Land is level and flat.
Thanks
Soooooo, what are you going to do?
   / How difficult to operate a mini excavator #64
Moss; I should have said Rome Plough or Disk. He ploughs were usually one or two bottom pulled by a D7 of the time. ( 1950 )
The dozer plows were a V type ( locomotive snow clearing type ) there would be a metal mesh cage around the cat & operator to deflect the tree spears. Sections of brush would be cleared at a time.
This type of plough only about three times as big.
   / How difficult to operate a mini excavator #67
yes I know I get that and have done it. But i was referring to basically having the ability to sell the logs or homeowners like to have ability to cut logs and use them for firewood.
Exclusively before trackhoes.
   / How difficult to operate a mini excavator #68
I think its safe to say he's not going to rent a machine like this. I guess there is a small possibility but unlikely.
   / How difficult to operate a mini excavator #69
Very true.
The picture got posted to show past methods.
I think I will probably not buy one because I would probably not want to sell it later when I am finished with the clearing. Also, I have learned that some repairs on these things can be very expensive.
I am going to get some quotes but I am sure it will be more than the $2000 that I can rent one for. So, I think I am going to rent one for a month after winter sets in and all of the leaves,have fallen off the trees. In a month I would also think I can have most if not all of the stuff burned.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
