How cold do you keep it?
/ How cold do you keep it?
We sleep with 2 quilts, and at least one fan, sometimes the ceiling fan too. In the winter we seldom use the heat at all.
The A/C has been freezing up since it was new, and we keep the filters clean. The A/C guy says I just keep it too cold, but thats BS because I kept it 60 in my old house it didn't freeze up.
/ How cold do you keep it? #22
Def. love my AC.. no central(old log cabin).. but two AC window units on the 2nd floor.. and a big fan to push the air down one staircase.. and up the other.. the house stays very cool this way. Lately.. since my elect. meter totally stopped spinning around.. I've been blasting them on high.
One project I wanted to try was using the well water to cool w/.. it's so cold it makes you gasp! Has anyone tried this?
/ How cold do you keep it? #23
<font color="blue"> One project I wanted to try was using the well water to cool w/.. it's so cold it makes you gasp! Has anyone tried this? </font>
Yes, they call it ice cubes in your pajammas. Works great to cool you off. Just remember to seal the ziplock bag /forums/images/graemlins/tongue.gif
But seriously...
There was an old theatre here in South Bend, IN called the Colfax. It had a sloped floor like all theatres. Under the rows of seats were vents to a plenum under the floor. In the basement of the theatre was a huge radiator looking device with a large well that pumped water through it. Always in the 50 degree range. They forced air through it and it cooled the entire theatre.
/ How cold do you keep it? #24
If your A/C is freezing up and your coil is clean you stand a good chance of being low on freon. Your low side should be around 75 PSI if you're running R-22. That's a ballpark figure on a hot humid day.
/ How cold do you keep it? #25
"ice cubes in your pajammas"
Maybe when I was younger.. just a "no" from the misses is all it takes now. /forums/images/graemlins/grin.gif
I was wondering if it would be $ wise sound.. still need the fan.. but no condensor.. but then a pump for water. My neighbor showed me a milk in-line pre-cooler that's cooled w/ well water before it reaches his milk cooling tank.. that's what got me thinking along those lines.
/ How cold do you keep it? #26
I don't care for it much below about 78. But all these post reminded me of a little joke in a book one time. The A/C man came to work on the thermostat, and the man told him, "no not that one, that one is for the wife, the real one is in the closet". /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ How cold do you keep it? #27
MY KIND OF GUY. with the a/c running i usually have the fan running, the wife like it cold also, mabey thats why in the winter we set the termostat at 57 at night, saves some $$$$ also.
/ How cold do you keep it? #28
We're setting on 71.6 F right now and have the bedroom zone turned down to 65 F. We both love it cold and we also run the ceiling fan and a desk fan 24/7/365. Just went on vacaton to Teton National Park and took a battery operated fan so I could have one in the tent /forums/images/graemlins/grin.gif
/ How cold do you keep it? #29
"We're setting on 71.6 F right now and have the bedroom zone turned down to 65 F. "
I have "zone A/C" too! The front window unit "zone" is at 72 degrees and the bedroom "zone" is about 62! /forums/images/graemlins/grin.gif
/ How cold do you keep it? #30
KENSFARM, If your deep earth temp is low enough (temp of well water fresh out of ground not from tank) you can cool with it. A consideration is that since the delta T is less than with a mechanical unit, you need a larger heat exchanger. Nevertheless it can be done.
There are capillary tube systems used for hydronic cooling applications. These are popular in Europe but now available in the US. A mesh of these fine tubes would be plastered into a ceiling or similar applcation and cool water (about 62F) is circulated through. This lowers the radiant temperature of the ceiling and tends to put your body in a radiant heat debt situation. It makes you sense the room as cool. You are radiating infra-red energy out in all directions and similarly receiving radiant energy from your environment. If the net effect is a heat loss you are cooled.
Consider how it feels to be in a warm room in the winter time and walk up close to a large window. You feel a sudden chill. It is not neccessarily a cold draft or leaky window. The energy your body radiates toward the window goes outside and a lot less comes back from the cold outdoor environment so you have a net loss and feel cold.
By lowering the temp of large surfaces (ceiling is usually the best) you lower the intensity of your radiant environment and you give up radiant heat to the cool surface. There are limits to this radiant cooling. If you try to make it too cool you get condensation on the cooled surface. Some supplemental dehumidification (undersized A/C unit running hard and not keeping up is real good one) helps a lot.
This sort of cooling is a good match to your situation as its "design temp" is within the range of what your water will supply with no additional mechanical cooling. The cost of circulating your cold water is way less than running a big heat pump. Too many variables to guestimate payback but there are definite possibilities worth exploring. Unfortunately VERY FEW HVAC guys are HVAC design engineers and few HVAC engineers (in the US) are experienced with hydronic cooling. It is not particularly difficult. It is a fairly straight forward physics application.
If your water is cold enough you may be able to run some through a water to air heat exchanger with slow air movement and get a decent rate of dehumidification. I could mock that up with an old truck radiator. Circulate the cold water slowly through the radiator and turn the radiator horizontal and mount high near the ceiling.
Warm moist ceiling air will be cooled and moisture will condense out (you'll need a drip pan/condensate collection/disposal arrangement.) As the warm air by the ceiling is cooled it will become heavier and will subside, falling through the radiator, whuch sucks more warm air into contact with the radiator. No air handler should be required for this demo system. The colder the water the better (above freezing of course). Mounting it high up near the ceiling will improve performance. The larger the radiator the better.
If you were to try to scale this up to handle your whole house, you have to choose betwen a centralized versus a distributed system. A distributed system could be installed in "troffers" and look sort of like recessed ceiling mounted fluorescent light fixtures. You could use the plastic open diffusers like some office lighting has to dress it up.
A centralized system would require more careful engineering to optimize air volume, flow rates, heat exchanger areas and such. It would be a whole lot easier for a DIY project to go with a distributed system. No duct work and no fans, just a little circulaltion pump. if you fed your house plumbing through this cooling system then whatever water you used in the household would be that much water you wouldn't have to pay to circulate.
The system I describe would dehumidify and do some cooling. There are commercial systems where pipes with chilled water are run in the air near the ceiling with troughs to catch condensate below them. Theaters and large meeting rooms have been done this way. The warm moist air rises and is cooled by the pipes. Some moisture is condensed out and falls into the drain trough below the pipe. Cooled air is heavier and falls back down toward the occupants. As the convection currents are weak and distributed there is no pwerception of a strong cold draft.
This sort of approach will help dehumidify and cool a residence but by itself will probably not satisfy some of the unabashed "polar bears" who have commented in this thread.
Hope you took notes as this material may be on the mid term exam.
Pat /forums/images/graemlins/smile.gif
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
John Deere 4240 w/ Buhler 695 Front End Loader (A64047)
John Deere 4240 w/...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
Sullair 185DPQ 100psi Towable Air Compressor (A61572)
Sullair 185DPQ...
2020 MACK GRANITE (A63569)
2020 MACK GRANITE...
