How are we doing?
/ How are we doing? #11
ldabe said:
Yeah! Who wouldn't?
I have the muffler with two ports also, but It seemed to me that the air from the exhaust only blew out one side.
Jack, buy the way, I had my engine oil filter come loose. Is that an unsual thing, or does the vibration cause that to be something that I should make a habit of checking to see if it is tight?
It is a bit of a pain to get to.
Thanks,
Abe.
I know you may already do this if not, might be something to try next time. Just coating the seal ring on your filter with a little oil may give you that extra half turn when you tighten down your filter.
I know it is (extremely hard) to get my big hands in the small engine compartment area to do this. So anything that = less resistance helps. To date mine has not come loose.;)
/ How are we doing? #12
I did have a slight oil leak laast year and it was the filter not being tight enough....whew!, thought I had MAJOR problems at first! Can't honestly say if it worked loose or if the installer(me) didn't tighten it enough...although I normally hand tighten as much as possible and then go 1/4 to 1/2 turn more with the filter wrench.
/ How are we doing? #13
I was always told to never use a wrench to put an oil filer on. Anyone else ever hear that?
/ How are we doing? #14
Yes--I have always understood, and I think the directions on most oil filters say, that the filter should be hand tightened. The directions also say to coat the gasket with oil--it prevents the gasket from sticking to the sealing surface when tightening or removing the filter.
/ How are we doing? #15
I also have heard not to use a wrench, unfortunatley arthitic conditions prohibit me from getting the filter tight enough by hand anymore. I learned the hard way years ago not to tighten with a wrench...that filter and the garage floor were a mess by the time I finiched mutilating the casing trying to get it off!
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1449 (A57192)
1449 (A57192)
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
2004 John Deere 4720 (A60462)
2004 John Deere...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
