How are GOOD trailers wired?
/ How are GOOD trailers wired? #41
grease on lamps atg their bayo base help too.. keeps water and air out.. prevents corosion and sticking..
same on the connector.. just protect it from attracting dirt by using a good connector with well fitting cover..
soudnguy
/ How are GOOD trailers wired? #42
Tractor supply sells the basic four wire plug in like a 15-20' length at a reasonable price. Also anywhere the wire passes through anything such as a metal hole put some good silicone around the wires, It will eliminate movement and also waterproof it.
Also it is money well spent on the oval lights as they are weatherproof and if they get busted you just unplug it and pop in a new one (with no tools)
Cant wait to see the finished product.
-Mills
/ How are GOOD trailers wired? #43
i like to use some rubber fuel line.. OR a correct grommet when passing cables thru metal flanges or holes.
soundguy
/ How are GOOD trailers wired? #44
soudnguy
You can buy the correct stuff, it's called dielectric grease, at most auto parts stores. It's a little less messy than regular grease and clear (at least the stuff I have) and is more like a petroleum jelly. But it's well worth putting some in every light socket.
/ How are GOOD trailers wired? #45
sure you can.. and my tube is almost never around when i need it.. but vasolene or chassie grease is always available... :)
soundguy
/ How are GOOD trailers wired? #47
i was just refering to the trade name... ie.. not scotch 'b'locks...
soundguy
/ How are GOOD trailers wired? #48
i was just refering to the trade name of scotch lock, vs scotch 'b'lock
soundguy
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
ATLAS 7' Box Blade (A60463)
ATLAS 7' Box Blade...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
