How about this tool??
   / How about this tool?? #21
If I had an assistant to hand me the wrenches, I think I would just go one step further, and let them do the job.
Kind of like, you might be a redneck if you say you would get a shop with a car hoist if you won millions. I don't think I would be pulling on a lot of wrenches.
   / How about this tool?? #22
Having to remove a mercury inboard /out board engine recemtly and all bolts were 9/16th. except the exhaust water jacket and below the level of seeing the bolts. no tool metric or standred would fit. took a vice grip and loosened one bolt .and didn't have a tool for torx type bolt. then realized a 12 point socket would fit. except didn't have in tool box. 15 mile trip to garage and return then again crawl into the small area on boat to remove the remaining 3 bolts. if I could make a change all bolts common group usage would be same size. because know will be when repairs completed and returning to the boat.
have a Creasent wrench my father hung on a 1952 Farmall H and on selling the tractor put it in my tool box. Now wish had not sold the tractor.
ken
   / How about this tool?? #23
That's why I don't change my own oil any more. Once down and once up is my limit.
I wrote the size of the drain plug on white Gorilla tape and stuck it under the hood. Last time I forgot it was there and did the multiple crawl thing anyway.
   / How about this tool?? #24
What I would like is the tool that you use to determine thread size and pitch. The only reason that I don't have one is because I don't know what it's called. :confused:
   / How about this tool?? #25
   / How about this tool?? #27
   / How about this tool?? #28
The thread cleaning files are what you want. I have 3 of them. Just lay it on the thread until you find the perfect fit.
thread files - Google Search
   / How about this tool?? #29
The square ones I used had 8 pitches on one file.
Bruce
   / How about this tool?? #30
Thats the ones Bruce. I added a link
Good piece of gear to have. Great for cleaning up damaged threads.
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
